On 02/02/2004 at 06:34, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.200 Platform: Windows ; Language(s) : C.O.F.F.E.E ; XPRESSO ;
--------- Hi all, do the EditText GUI resource automatically support drag and drop? I would like to be able to drag an object from the OM itnot a field in my GUI. CAn someone point me to a tutorial, or write up a small example for me?
Much thanks in advance
Sharriff
On 02/02/2004 at 09:24, xxxxxxxx wrote:
Hi, search the forum (and the old forum) please. This was discussed several times in here, and I provided a complete Code solution for this. Have fun seeking
On 03/02/2004 at 05:09, xxxxxxxx wrote:
Hallo,
I did a search before posting this, if I knew other searchwords for this issue I would have probably found something in the SDK. Besides, the archived forum code is broken. Help or keep the sarcastic comments to yourself.
"Microsoft VBScript runtime error '800a01f4' Variable is undefined: 'messagStatus' /includes/inc-forumfunctions.asp, line 123 "
On 09/02/2004 at 17:14, xxxxxxxx wrote:
I think this might be the thread that Samir was refering to: http://www.plugincafe.com/forum/display_topic_threads.asp?ForumID=4&TopicID=623 The forum search problem seems to have been intermittent because now it works. A common pitfall when searching is that it's set to only search subjects by default. I was able to find the above by searching for "EditText drag" in the body text. Did the code example help?
On 10/02/2004 at 01:41, xxxxxxxx wrote:
Thanks so much Mikael I would read the whole thread. I´ll let you know if I have problems.
