On 04/01/2015 at 20:57, xxxxxxxx wrote:
Whenever we hover the mouse over a button it gets highlighted. Is there any option to turn it off.
Thanks. Nishant
On 05/01/2015 at 05:16, xxxxxxxx wrote:
for standard buttons, I don't think this is possible. But you could use a bitmap button instead. Of course this implies doing the button graphics yourself.
EDIT: Sorry, my first attempt was no good.
Of course the standard buttons don't have any highlighting at all. So I guess your question is actually referring to BitmapButtons. I hope to return with a solution tomorrow.
On 06/01/2015 at 02:49, xxxxxxxx wrote:
Nishant,
the BitmapButton has no option to deactivate the highlighting on mouse over. You can fake it by setting the background color of the BitmapButton, but this is impossible via resource file.
You'll need to modify your bitmap button dynamically in GetDDescription(). Unfortunately GetDDescription() is not available via Python...
In C++ it would look like so:
Bool MyPlugin::GetDDescription(GeListNode* node, Description* description, DESCFLAGS_DESC& flags) { const DescID* singleid; DescID cid; BaseContainer* bcDesc; if (!description->LoadDescription(node->GetType())) return FALSE; singleid = description->GetSingleDescID(); cid = DescLevel(YOUR_BITMAP_BUTTON_ID, CUSTOMDATATYPE_BITMAPBUTTON, 0); if ((!singleid) || (cid.IsPartOf(*singleid, NULL))) { bcDesc = description->GetParameterI(cid, NULL); bcDesc->SetLong(BITMAPBUTTON_BACKCOLOR, COLOR_BGFOCUS); // you may choose other colors here } flags |= DESCFLAGS_DESC_LOADED; return TRUE; }
On 06/01/2015 at 21:34, xxxxxxxx wrote:
Thanks
On 14/03/2017 at 05:37, xxxxxxxx wrote:
Since Cinema 4D version 18.011 GetDDescription() is available in Python as well.
