Bug in C.O.F.F.E.E. node [SOLVED]
On 04/01/2015 at 09:10, xxxxxxxx wrote:
Cinema 4D Version:   R16
Platform:      Mac OSX  ;
I have an xpresso file with a C.O.F.F.E.E. node.
This is the code:
  if (body == 0)
          arms = 0;
      } elif (body == 1) {
          arms = 1;
      } elif (body == 2) {
          arms = 1;
      } elif (body == 3) {
          arms = 1;
      } elif (body == 4) {
          arms = 2;
Where body and arms are two variables of the type integer.
But I get a COFFE ERROR! Variable or function expected
Line: 6
Row: 13
which is, after the first elif, and after the open parenthesis: body, which is a variable.
Does somebody see the problem here?
Thanks in advance for your help! 🙂
On 04/01/2015 at 23:53, xxxxxxxx wrote:
"elif" keyword doesn't exist in C.O.F.F.E.E.
Use "else if" instead.
On 05/01/2015 at 02:15, xxxxxxxx wrote:
Thanks for your answer!
I should clearly pay more attention to which language I'm using.
Guess I'm too much used to Python 😛
On 05/01/2015 at 05:52, xxxxxxxx wrote:
Howdy,
You could also simplify your code like this:
	arms = body;
	if(body > 1 && body < 4) arms = 1;
	else if(body > 3) arms = 2;
Adios,
Cactus Dan
On 05/01/2015 at 06:08, xxxxxxxx wrote:
That's right!
Thanks for your help!!
Greetings,
Casimir Smets
