Changing layout in object plugin [SOLVED]
On 12/12/2014 at 11:53, xxxxxxxx wrote:
I have a custom object, I want to check a checkbox and have that disable fields or add/remove fields.
Similar to the 'Physical Sky' when you check the Sky, Sun, Atmosphere, and Clouds bool it appears more menu groups.
Is this possible?
On 12/12/2014 at 12:02, xxxxxxxx wrote:
please have a look at this thread:
https://plugincafe.maxon.net/topic/8350/10900_pluginsobjectdata-enablegadget-solvedBest wishes
Martin
On 12/12/2014 at 15:04, xxxxxxxx wrote:
Thanks Martin
On 14/12/2014 at 10:49, xxxxxxxx wrote:
That works. One more thing, Could I dynamically populate combo boxes through python?
On 15/12/2014 at 07:12, xxxxxxxx wrote:
Hello Joe,
I´m not the guy who want to tell you what to do, but I guess you wont get your question answered if you post a completly new question on an allready solved thread in the future. ;)
To your question:
As far as I know, it is possible, if you add your combo box within the python file, but not with a res based gadget.
But I could be wrong with this.
Best wishes
Martin
