On 11/12/2014 at 08:16, xxxxxxxx wrote:
I have an object with a Constraint Tag. Now I want set Clamp - Align = +Z
If I look in the console what to set I get: Constraint[50004,3] How to set this value using Python (container)?
-Pim
On 11/12/2014 at 08:40, xxxxxxxx wrote:
Hi Pim, you know how to ensure you get the right tag and object and so on. That´s why here is only the short form:
contag = op.GetTag(1019364) contag[c4d.ID_CA_CONSTRAINT_TAG_CLAMP] = True contag[50004,3] = 5 c4d.EventAdd()
Best wishes Martin
On 11/12/2014 at 08:55, xxxxxxxx wrote:
as always I suggest to use the proper constants, in this case c4d.ID_CA_CONSTRAINT_TAG_AXIS_ZP .
Be aware that a constraint tag could have multiple clamp targets. To get the count of the targets simply access ID_CA_CONSTRAINT_TAG_CLAMP_TARGET_COUNT.
Best wishes, Sebastian
On 11/12/2014 at 23:57, xxxxxxxx wrote:
Thanks. Reading my question again, I realized I should have know this myself. After all Cube[c4d.ID_BASEOBJECT_REL_POSITION,c4d.VECTOR_Y] is about the same. I guess mixing c++ and python, mixes up my brain.
