On 03/12/2014 at 13:55, xxxxxxxx wrote:
I have a plugin with FILENAME FILE01_LINK { } in the .res file.
In the .pyp file I have the following:
FILE01_LINK = 1005,
def Init(self, op) : self.InitAttr(op, str, [1005]) op[1005] = "Test"
For some reason I can't get any text to display in the file text field, unless I type it in or load a file by clicking on the ... to the right of the file input area. When I drag the description text into the console I get: print pluginTest[c4d.FILE01_LINK] OK On the next line the console prints Test This confirms that my File string is in memory as the value of op[1005], but it is not being displayed to the user. What could cause this? I can show more of my plugin if needed.
On 03/12/2014 at 14:47, xxxxxxxx wrote:
is there a reason why you don´t use
self.SetFilename(FILE01_LINK,"test")
inside your init function?
Best wishes Martin
On 03/12/2014 at 15:17, xxxxxxxx wrote:
Ya know, too often it's the little, overlooked thing that can stump me all day. Thank you, that worked!
Thanks again, David
