moving the axes and let the polygon stay [SOLVED]
  • On 19/11/2014 at 13:59, xxxxxxxx wrote:
    Hi all,
    I want to move a polygon with his axis to Y=0 and let the polygon
    stay above it?
    To move the axis to 0 is no Problem.
    But what do I have to do that the polygon will stay above?
    Any ideas.
    Thanks a lot
  • On 20/11/2014 at 08:39, xxxxxxxx wrote:
    it seems there is no dedicated function to do this. You can edit the axis of an point object by moving the object and then transform the points of the object:
      if op == None:
      if op.IsInstanceOf(c4d.Opoint) == False:
      # the offset of the axis
      offset = c4d.Vector(100,0,0)
      # move object
      m = op.GetMg()
      m.off = m.off + offset
      op.SetMg(m)
      # transform points
      padr = op.GetAllPoints()
      pcnt = op.GetPointCount()
      for i, point in enumerate(padr) :
          point = point - offset
          op.SetPoint(i,point)
      op.Message(c4d.MSG_UPDATE)
    In a more complex situation you may have to work with a offset matrix.
    best wishes,
    Sebastian
  • On 21/11/2014 at 00:56, xxxxxxxx wrote:
    Hey you arre my hero :-)
    Thanks for your code.
    Ronald
