OBJECT_OPERATOR_OBJECT_OUT
On 18/11/2014 at 06:52, xxxxxxxx wrote:
I'm working on a python script.
I want to make some expresso nodes with it.
Adding the node and a position-output port works fine, but when I try to add an object-output port it does nothing.
No errors, but no port as well.Here is the code I use:
from c4d import gui
#Welcome to the world of Pythondef main() :
pointobject = doc.GetActiveObject()xpressotag = c4d.BaseTag(c4d.Texpresso)
xpressotag.SetName("PointLock XPresso")
op.InsertTag(xpressotag)
nodemaster = xpressotag.GetNodeMaster()
basenode = nodemaster.CreateNode(nodemaster.GetRoot(), c4d.ID_OPERATOR_OBJECT, None, 100, 100)
basenodeobjectoutput = basenode.AddPort(c4d.GV_PORT_OUTPUT, c4d.GV_OBJECT_OPERATOR_OBJECT_OUT)
basenodepositionoutput = basenode.AddPort(c4d.GV_PORT_OUTPUT, c4d.ID_BASEOBJECT_REL_POSITION)
c4d.modules.graphview.RedrawMaster(nodemaster)
c4d.EventAdd()if __name__=='__main__':
main()I think there isn't anything wrong with my code, and I found "GV_OBJECT_OPERATOR_OBJECT_OUT inside Applications -> CINEMA 4D R16 -> resource -> modules -> expression tag -> description -> gvobject.res
What I want is the port to be added.
Thanks in advance for your help and time!
Greetings,Casimir
On 18/11/2014 at 07:26, xxxxxxxx wrote:
Correct me if I'm wrong but I am pretty sure this Port is broken in python. I haven't used that bit of code in R16 yet but from the sound of it, it's still broken? What I have done to bypass this is to add a link userdata to the object and add the object to the link and then make an output port for the link. (A lot of unnecessary code)
On 19/11/2014 at 03:55, xxxxxxxx wrote:
thanks for reporting this. A bug report was filed.
Best wishes,
Sebastian
On 20/11/2014 at 03:05, xxxxxxxx wrote:
Hi Sebastian,
Do you know when (approximately) the bug will be fixed?
@ShawnFrueh, thanks, I'll look into it!
On 20/11/2014 at 08:15, xxxxxxxx wrote:
I don't know when this bug will be fixed. Also I can't make any statements about future Cinema 4D releases.
best wishes,
Sebastian
On 21/11/2014 at 06:58, xxxxxxxx wrote:
@ShawnFrueh,
Thanks again for your answer!
After a bit of digging how to make user data I came up with a perfectly working script to create an object port, like you did it!Here is my code, for the people not yet understanding it:
from c4d import gui
userdata = c4d.GetCustomDatatypeDefault(c4d.DTYPE_BASELISTLINK)
userdata[c4d.DESC_NAME] = "Object Data"
linkobject = op.AddUserData(userdata)
op[linkobject] = opxpressotag = c4d.BaseTag(c4d.Texpresso)
basenodeobjectoutput = basenode.AddPort(c4d.GV_PORT_OUTPUT, c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA, c4d.DTYPE_SUBCONTAINER, 0), c4d.DescLevel(1)), message = True)
main()Greetings,
Casimir
On 21/11/2014 at 09:15, xxxxxxxx wrote:
Glad I could help :)
