User Data, Xpresso, Python [SOLVED]
On 13/11/2014 at 02:21, xxxxxxxx wrote:
Hello
_<_t_>_
English »
| < id="SL_lng_to">< value="af">Afrikaans< value="sq">Albanian< value="ar">Arabic< value="hy">Armenian< value="az">Azerbaijani< value="eu">Basque< value="bn">Bengali< value="be">Belarusian< value="bg">Bulgarian< value="ca">Catalan< value="zh-CN">Chinese (Simp)< value="zh-TW">Chinese (Trad)< value="hr">Croatian< value="cs">Czech< value="da">Danish< value="nl">Dutch< value="en">English< value="eo">Esperanto< value="et">Estonian< value="tl">Filipino< value="fi">Finnish< value="fr">French< value="gl">Galician< value="ka">Georgian< value="de">German< value="el">Greek< value="gu">Gujarati< value="ht">Haitian Creole< value="iw">Hebrew< value="hi">Hindi< value="hu">Hungarian< value="is">Icelandic< value="id">Indonesian< value="ga">Irish< value="it">Italian< value="ja">Japanese< value="kn">Kannada< value="ko">Korean< value="lo">Lao< value="la">Latin< value="lv">Latvian< value="lt">Lithuanian< value="mk">Macedonian< value="ms">Malay< value="mt">Maltese< value="no">Norwegian< value="fa">Persian< value="pl">Polish< value="pt">Portuguese< value="ro">Romanian< value="ru">Russian< value="sr">Serbian< value="sk">Slovak< value="sl">Slovenian< ed="" value="es">Spanish< value="sw">Swahili< value="sv">Swedish< value="ta">Tamil< value="te">Telugu< value="th">Thai< value="tr">Turkish< value="uk">Ukrainian< value="ur">Urdu< value="vi">Vietnamese< value="cy">Welsh< value="yi">Yiddish| |
<_<_t_>_
Options : History : Help : Feedback
Text-to-speech function is limited to 100 charactersI want to create xpresso structure with connections via python script.
Basic ports are created without problems, but the problem occurs when i create port with User Data - node stops working, and title bar painted yellow.
If create port manually - all works.This code create node and port:
[](http://www.html.by/misc.php?do=bbcode#CODE) XP=c4d.BaseTag(c4d.Texpresso) obj.InsertTag(XP) Node_M=XP.GetNodeMaster() Base_Node=Node_M.CreateNode(Node_M.GetRoot(), c4d.ID_OPERATOR_OBJECT, None, 0, 0) Base_Node.AddPort(c4d.GV_PORT_OUTPUT, [c4d.ID_USERDATA,1] ,c4d.GV_PORT_FLAG_IS_VISIBLE,True)[
#Sorry for my english.
On 14/11/2014 at 01:28, xxxxxxxx wrote:
To create ports for userdata parameters you have to create the DescID of that parameter.
USERDATA_NUMERO = 1 #change this nodeObjOut.AddPort(c4d.GV_PORT_OUTPUT, c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA, c4d.DTYPE_SUBCONTAINER, 0), c4d.DescLevel(USERDATA_NUMERO)), message=True)
This example is taken from this thread describing the solution.
best wishes,
Sebastian
On 16/11/2014 at 02:06, xxxxxxxx wrote:
Thank you very much!
On 16/11/2014 at 03:46, xxxxxxxx wrote:
And another question.
I created this node manually(pic1)But i want create this node via Python script, how can i make it? Any ideas?
_<_t_>_
English »
<_<_t_>_
On 17/11/2014 at 01:54, xxxxxxxx wrote:
do you want to edit the reference parameter of the given node? Just use SetParameter() to link a given object. The list of parameters of the object node can be found on the C++ documentation.
baseNode.SetParameter(c4d.GV_OBJECT_OBJECT_ID,linkedObject,c4d.DESCFLAGS_SET_0)
Best wishes,
Sebastian
On 24/11/2014 at 06:52, xxxxxxxx wrote:
Thanks, it works.
_<_t_>_
English »
<_<_t_>_
But it is for R16, what about the older versions?
On 24/11/2014 at 09:24, xxxxxxxx wrote:
in this case just use
baseNode[c4d.GV_OBJECT_OBJECT_ID] = linkedObject
best wishes,
Sebastian
