questions about GetDDescription [SOLVED]
On 03/11/2014 at 15:43, xxxxxxxx wrote:
Cinema 4D Version: 13+
Platform: Windows ;
I have checked _LookAtCamera example, and this thread https://plugincafe.maxon.net/topic/7716/9757_how-to-dynamically-add-description-elements&KW=GetDDescriptionI understand how it works to some extent, but got some questions:
1- in _ _LookAtCamera example, there is this snippet:const DescID* singleid = description->GetSingleDescID();
DescID cid = DescLevel(6001, DTYPE_GROUP, 0);
if (!singleid || cid.IsPartOf(*singleid, nullptr)) // important to check for speedup c4d!
{;//code here}_GetSingleDescID() is not documented, so correct me at these points:
a- I consider if it succeeds , it returns a value to singleid
b- this if statement is entered only once at the first creation of the description elements, so it fits ONLY to non-changeable descriptions "similar to creating GUI using text files instead of C++ functions" , and I expect it to create garbage for a truly dynamic GUI
c- initial values are 0 (because they are not set in the init function), so why using _SetBool(DESC_DEFAULT, true)2- the seconds question is so simple, I want to put the GUI in columns, similar to when you startup Cinema 4D, in the Project settings:
FPS.......................30 Project Time........... 0 f
Minimum Time......0 f Maximum Time ...... 90 f3- what if I want to create a whole command menu inside a "right click", so if the user did a right click on a specific "gui text" this command menu appears
_
On 04/11/2014 at 02:45, xxxxxxxx wrote:
for the ( 1-c ) question, I understand now how it works, it is the value of "reset to default" , other questions still need answers
edit:
about question ( 2 ) , I know how to do it now, from this example: http://www.andrewnoske.com/wiki/Cinema_4D\_-\_my_C%2B%2B_plugins\_-\_object_converter
On 04/11/2014 at 05:44, xxxxxxxx wrote:
Sometimes, Cinema will ask you for the description of only a single element. If the singleid you get is not nullptr, you should fill the Description only for this DescID and leave everything else out (important for performance reasons)
On 04/11/2014 at 07:35, xxxxxxxx wrote:
thanks Niklas for clarification, so this function won't change the behavior of anything, just a performance check "so I can put it there and forget about it without worries"
what about question 3
On 04/11/2014 at 11:15, xxxxxxxx wrote:
Hi Mohamed,
sorry, I wanted to get to your issues way earlier...
To be honest, I'm not sure about question 3. I know, you can have your own popup menu (I think, that's what it is called in SDK docs) on a GeUserArea, when programming your own CustomGUI. But I don't think this is possible in normal descriptions. And I don't recall having seen this anywhere. Could you give me a pointer, if (and if, where) this is already done somewhere in C4D.
There is an option to extend the existing popup menus in the same way, as normal menus (see Windows->Customization->Customize Menus to get an idea of the existing menus). Be aware: In this case your change will appear in every occasion this menu is used. I think, there should be very good reasons to go this road. User may not like, getting there popup menus changed.
On 04/11/2014 at 11:38, xxxxxxxx wrote:
Hi Andreas,
I think with your reply I'm getting closer to what I need
I'm creating a node based material system for my render engine, this material system will have also a tree view representation, this tree view should be able to do "right click" , then add nodes depending on the right click menuI think you got now an idea about what I'm after, any simple example of GeUserArea and CustomGUI would be appreciated, plus your guidelines
On 04/11/2014 at 13:37, xxxxxxxx wrote:
I'll extend the asynctest SDK example tomorrow morning to have a small popup menu.
On 04/11/2014 at 23:00, xxxxxxxx wrote:
Mohamed,
in SDK examples AsyncTest.cpp add the following enumeration for some menu IDs (code for R15+) :
enum { MY_POPUP_ID_FIRST = FIRST_POPUP_ID, MY_POPUP_ID_SUBMENU, MY_POPUP_ID_SUBMENU_FIRST, };
Then in Bool SDKGradientArea::InputEvent(const BaseContainer& msg) add the following as last else if:
else if (chn == BFM_INPUT_MOUSERIGHT) { BaseContainer bcPopupMenu; BaseContainer bcSubmenu; Int32 mx = msg.GetInt32(BFM_INPUT_X); // of course you can use mouse position to have popup menu be position sensitive Int32 my = msg.GetInt32(BFM_INPUT_Y); Global2Local(&mx, &my); Local2Screen(&mx, &my); // instead of building the menu everytime, you may better have a prepared container ready bcPopupMenu.SetString(MY_POPUP_ID_FIRST, "First menu entry"); bcSubmenu.SetString(1, "A submenu"); bcSubmenu.SetString(MY_POPUP_ID_SUBMENU_FIRST, "Submenu entry"); bcPopupMenu.SetContainer(MY_POPUP_ID_SUBMENU, bcSubmenu); const Int32 menuId = ShowPopupMenu(nullptr, mx, my, bcPopupMenu); switch (menuId) { case MY_POPUP_ID_FIRST: GePrint("Execute first popupmenu entry"); break; case MY_POPUP_ID_SUBMENU_FIRST: GePrint("Execute first submenu entry"); break; case 0: GePrint("Menu got canceled"); break; default: DebugStop("Popup Menu: Forgot a new enum value?"); } // maybe use SendParentMessage() if need be }
The docs on this topic aren't that bad either: R16 SDK Docs: c4d_gui.h
On 05/11/2014 at 02:54, xxxxxxxx wrote:
thanks a lot , will test tonight and come back to you
On 05/11/2014 at 14:25, xxxxxxxx wrote:
Hi Andreas,
I have checked it!! , it is a very interesting example
, this is really very helpful, thanks again for your support, keep the good work up
On 06/11/2014 at 02:13, xxxxxxxx wrote:
just need to confirm about question ( 1-a , 1-b ) , I use this if statement in all created description, or no need at all? need some discussion about what happens here
On 06/11/2014 at 02:17, xxxxxxxx wrote:
Can you show me a piece of your code? Will make discussion easier.
On 06/11/2014 at 03:00, xxxxxxxx wrote:
it is the example LookAtCamera , LookAtCamera::GetDDescription(), all of the written description are created the same way with a check for performance, need to understand how this works, if there is no specific explanation , is it safe to do the same with all created description? (so I just write them the same way and forget about them) , or this is written in specific situations
On 06/11/2014 at 03:43, xxxxxxxx wrote:
You mean the
if (!singleid ||...
part?
Yes, you should do it exactly like it is done in the lookatcamera example. As Niklas said, it's a performance optimization, in case C4D is asking for a single description only.
On 06/11/2014 at 04:13, xxxxxxxx wrote:
yes
ok thanks
On 17/11/2014 at 10:01, xxxxxxxx wrote:
sorry for asking again, but I found that I didn't know yet how to adjust the format of data "question (2)" , the above link that I posted was for Dialogs, didn't notice this, so hope you may reply with a simple example to question (2)
edit:I find that DESC_COLUMNS is doing the job, but what about putting stuff in an irregular way, like:
button1 button2 button3
button4
button5 button6
button7edit2: I would love to know how to create something similar to this Dialog http://www.andrewnoske.com/wiki/Cinema_4D_-_my_C%2B%2B_plugins_-_add_text
in GetDDescription() , the combo box, the radio group, etc..
On 17/11/2014 at 12:10, xxxxxxxx wrote:
nvm, I find the solution here:
https://plugincafe.maxon.net/topic/7380/8990_getting-dynamically-added-long-cycle-string-value&KW=GetDDescription
On 17/11/2014 at 14:05, xxxxxxxx wrote:
Ah, you were too quick. I was just compiling an example for you...
Nevertheless glad you found your solution.
On 11/01/2016 at 05:14, xxxxxxxx wrote:
Hi Andreas,
as this is related to ShowPopupMenu()
how to put icons in the menu?
