On 30/10/2014 at 03:52, xxxxxxxx wrote:
Cinema 4D Version: r14
Platform: Windows ;
Language(s) : C++ ;
Hi there,
i am having a hard time getting some handles to work. Most do what i think they should, but the last two (front/rear) don't. these get a weird offset as soon as i start dragging them.
here is my code:
#define pluginID 1000001
#define pluginName "test"
#include "c4d.h"
#include "c4d_symbols.h"
#include "c4d_gui.h"
#include "test.h"
class test : public ObjectData
INSTANCEOF(test,ObjectData);
private:
Real width,length,height,midOffset,front,rear;
public:
virtual BaseObject* GetVirtualObjects(BaseObject *op, HierarchyHelp *hh);
virtual Bool Message(GeListNode *node, LONG type, void *t_data);
static NodeData *Alloc(void) { return gNew test; }
virtual Bool Init(GeListNode *node);
virtual Bool GetDParameter(GeListNode *node, const DescID &id, GeData &t_data, DESCFLAGS_GET &flags) ;
virtual Bool GetDDescription(GeListNode *node, Description *description, DESCFLAGS_DESC &flags);
virtual Bool readParameters(BaseObject* op);
virtual LONG GetHandleCount(BaseObject *op);
virtual void GetHandle(BaseObject *op, LONG id, HandleInfo &info);
virtual void SetHandle(BaseObject *op, LONG i, Vector p, const HandleInfo &info);
virtual DRAWRESULT Draw(BaseObject *op, DRAWPASS type, BaseDraw *bd, BaseDrawHelp *bh);
Bool test::Init(GeListNode *node)
BaseObject *op = (BaseObject* )node;
if (!op) return false;
BaseContainer *data = op->GetDataInstance();
if (!data) return false;
data->SetReal(WIDTH,100.0);
data->SetReal(HEIGHT,100.0);
data->SetReal(LENGTH,100.0);
data->SetReal(MIDOFFSET,0.0);
data->SetReal(FRONT,25.0);
data->SetReal(REAR,25.0);
return true;
Bool test::GetDParameter(GeListNode *node, const DescID &id, GeData &t_data, DESCFLAGS_GET &flags)
return SUPER::GetDParameter(node, id, t_data, flags);
Bool test::GetDDescription(GeListNode *node, Description *description, DESCFLAGS_DESC &flags)
if (!description->LoadDescription(node->GetType())) return false;
readParameters((BaseObject* )node);
flags |= DESCFLAGS_DESC_LOADED;
return SUPER::GetDDescription(node, description, flags);
Bool test::Message(GeListNode *node, LONG type, void *t_data)
return true;
Bool test::readParameters(BaseObject* op)
BaseContainer* bc = op->GetDataInstance();
if (!bc) return false;
width = bc->GetReal(WIDTH);
length = bc->GetReal(LENGTH);
height = bc->GetReal(HEIGHT);
midOffset = bc->GetReal(MIDOFFSET);
front = bc->GetReal(FRONT);
rear = bc->GetReal(REAR);
return true;
BaseObject *test::GetVirtualObjects(BaseObject *op, HierarchyHelp *hh)
Bool dirty = op->CheckCache(hh) || op->IsDirty(DIRTYFLAGS_DATA);
dirty = dirty || !op->CompareDependenceList();
if (!dirty)
return op->GetCache(hh);
BaseObject *main = BaseObject::Alloc(Onull);
main->SetName("test");
if (main)
main->SetAbsPos(Vector(width*0.5,0,length*0.5));
return main;
return NULL;
Bool Register_test(void)
GePrint(pluginName);
return RegisterObjectPlugin(pluginID,pluginName,OBJECT_GENERATOR|OBJECT_INPUT,test::Alloc,"Test",AutoBitmap("test.tif"),0);
/* Handles */
LONG test::GetHandleCount(BaseObject *op)
return 6;
void test::GetHandle(BaseObject *op, LONG id, HandleInfo &info)
switch (id)
case 0:
info.position = Vector(width, 0.0, 0.0);
info.direction = Vector(1.0, 0.0, 0.0);
break;
case 1:
info.position = Vector(0.0, 0.0, length);
info.direction = Vector(0.0, 0.0, 1.0);
break;
case 2:
info.position = Vector(width*0.5+midOffset, height, length*0.5);
info.direction = Vector(0.0, 1.0, 0.0);
break;
case 3:
info.position = Vector(width*0.5+midOffset, 0.0, 0.0);
break;
case 4:
info.position = Vector(width*0.5+midOffset, height, front);
break;
case 5:
info.position = Vector(width*0.5+midOffset, height, length-rear);
break;
info.type = HANDLECONSTRAINTTYPE_LINEAR;
void test::SetHandle(BaseObject *op, LONG i, Vector p, const HandleInfo &info)
BaseContainer *bc = op->GetDataInstance();
if (!bc) return;
HandleInfo inf;
GetHandle(op, i, inf);
float val = (p - inf.position) * inf.direction;
switch (i)
case 0: bc->SetReal(WIDTH, bc->GetReal(WIDTH)+val); break;
case 1: bc->SetReal(LENGTH, bc->GetReal(LENGTH)+val); break;
case 2: bc->SetReal(HEIGHT, bc->GetReal(HEIGHT)+val); break;
case 3: bc->SetReal(MIDOFFSET, bc->GetReal(MIDOFFSET)+val); break;
case 4: bc->SetReal(FRONT, bc->GetReal(FRONT)+val); break;
case 5: bc->SetReal(REAR, bc->GetReal(REAR)-val); break;
DRAWRESULT test::Draw(BaseObject *op, DRAWPASS type, BaseDraw *bd, BaseDrawHelp *bh)
if (type==DRAWPASS_HANDLES)
LONG i;
HandleInfo info;
Matrix m=bh->GetMg();
bd->SetMatrix_Matrix(op, m);
bd->SetPen(Vector(1.0,1.0,1.0));
bd->SetPointSize(5.0);
for (i = GetHandleCount(op) - 1; i >= 0; --i)
GetHandle(op, i, info);
bd->DrawHandle(info.position, DRAWHANDLE_CUSTOM, 0);
bd->DrawLine(Vector(0.0,0.0,0.0),Vector(0.0,0.0,length),NOCLIP_D);
bd->DrawLine(Vector(width*0.5+midOffset,0.0,0.0),Vector(width*0.5+midOffset,0.0,length),NOCLIP_D);
bd->DrawLine(Vector(width,0.0,0.0),Vector(width,0.0,length),NOCLIP_D);
bd->DrawLine(Vector(0.0,0.0,length),Vector(width,0.0,length),NOCLIP_D);
bd->DrawLine(Vector(0.0,0.0,0.0),Vector(width,0.0,0.0),NOCLIP_D);
bd->DrawLine(Vector(width*0.5+midOffset,0.0,length*0.5),Vector(width*0.5+midOffset,height,length*0.5),NOCLIP_D);
bd->DrawLine(Vector(width*0.5+midOffset,height,front),Vector(width*0.5+midOffset,height,length-rear),NOCLIP_D);
return SUPER::Draw(op, type, bd, bh);
hopefully someone can jump in and show my what i am doing wrong.
cheers,
ello
