On 28/10/2014 at 12:59, xxxxxxxx wrote:
User Information: Cinema 4D Version: r14 Platform: Windows ; Language(s) : C++ ;
--------- Hi there, can someone point me to what i am doing wrong here? Basically i want to use the UniqueIP of different objects within a shader, but it doesn't work. shouldn' this apply different shades of red to each object?
Vector uniqueIDshader::Output(BaseShader *chn, ChannelData *cd) { Vector result = Vector(0.0); if (cd->vd) { RayObject *robj = NULL; robj = cd->vd->op; if (!robj) return 0.0; LONG uniqueID = robj->link->GetUniqueIP(); result.x = (uniqueID%255)/255.0; return result; } return result; }
edit: generally i'd like to have a random number for each object the shader is assigned to and i thought the unique ip could be used for the random init.
thanks, Ello
On 29/10/2014 at 02:06, xxxxxxxx wrote:
A RayObject's link parameter references to the polygon object that was the base for creating that RayObject. This polygon object way be a virtual object in a generator's cache, so it may not have a valid value for UniqueIP. So you could check the generator object (via GetCacheParent()) for it's UniqueIP.
But be sure to understand how GetUniqueIP() works. This function will not return a unique number for each element in the scene. It will return a number that is unique in the specific hierarchy level. The numbers of all parents / children in a branch create a unique IP.
If you need a truly unique ID you may take a look at GetGUID().
best wishes, Sebastian
On 29/10/2014 at 03:07, xxxxxxxx wrote:
thank you very much! exactly that solved the problem...
On 29/10/2014 at 07:55, xxxxxxxx wrote:
I'm confused how this code can work? Because the shader code that runs inside of: if(cd->vd){ } does not run until the scene is rendered for me. So the values are gibberish until the scene is rendered at least once.
if(cd->vd) { BaseObject *obj = cd->vd->op->link->GetCacheParent(); if(!obj) return 0.0; GePrint(obj->GetName()); //<--returns "Object" until the scene is rendered Matrix mtx = obj->GetMg(); GePrint(RealToString(mtx.off.x)); //<--returns -1.7 until the scene is rendered }
How are you getting accurate values from this code without rendering the scene?
On 29/10/2014 at 07:57, xxxxxxxx wrote:
it is only working when rendered. is it possible to pass colors in the editor view? if so i would be very interested in how
On 30/10/2014 at 01:30, xxxxxxxx wrote:
The VoumeData property of the ChannelData argument is only set when Cinema uses the shader to render a scene. But a shader is also called in two other situations.
When the shader preview image is calculated. Cinema will sample the shader to create this preview image using different UV-coordinates.
When the viewport preview texture is calculated. Cinema will bake the shader into a 2D texture to create a preview in the viewport. Also in this situation only the UV-coordinates change during sampling. If you want to define that viewport preview texture yourself you can override InitGLImage().
