Global variable problem [SOLVED]
On 28/10/2014 at 10:57, xxxxxxxx wrote:
Hi
I'm trying to get global variables working - I have a strange problem where if make a comparison test - I can no longer change the value afterwards without crashing.
for example...
> import c4d
> from c4d import gui
> #Welcome to the world of Python
> def main() :
>     if x != y:
>         y = 0
>         print y
> if __name__=='__main__':
>     x = 3
>     y = 7
>     main()
gives the error,
UnboundLocalError: local variable 'y' referenced before assignment
On 28/10/2014 at 12:39, xxxxxxxx wrote:
an example.
def settings() :
  global x,y
  x=3
  y=6
  return x,y
def main() :
  global x,y
  settings()
  if x != y:
      y = 0
      print y
Best wishes
Martin
On 28/10/2014 at 12:56, xxxxxxxx wrote:
Thanks for that Martin!
On 28/10/2014 at 13:24, xxxxxxxx wrote:
you´re welcome
another one:
depends on what you´re going to do
global x,y
x=6
y=5
def main() :
  global x,y
  if x != y:
      y = 0
      print y
On 28/10/2014 at 14:04, xxxxxxxx wrote:
yeah that looks a bit simpler - cheers 🙂
