Editor draw in a object plugin[SOLVED]
On 22/10/2014 at 13:15, xxxxxxxx wrote:
Does anyone have a sample object plugin they would be willing to share?
I'm using it to simply do what a null does (store children) but it has custom functions.
My issue is what it looks like in the editor. If I "include Onull" in the .res file, i can control parameters for what it should draw, but it doesn't work. Is it possible to use those draw parameters and get it to work?
If not, then just drawing a flat square would be fine. (it would need to scale and rotate with the op).
Thanks,
Joe
On 22/10/2014 at 17:54, xxxxxxxx wrote:
Hi Joe,
two month ago I used a gizmo box for doing somthing similar.
I´m not sure, if that helps.
  def Draw(self, node, drawpass, bd, bh) :
      if drawpass==c4d.DRAWPASS_HANDLES:
          data= node.GetDataInstance()
          size= data.GetVector(10001)/2
          mat = node.GetMg()
          bd.SetMatrix_Matrix(None, mat)
          box = c4d.Matrix()
          box.v1 = box.v1 * size.x
          box.v2 = box.v2 * size.y
          box.v3 = box.v3 * size.z
          bd.DrawBox(box, 1.0, c4d.GetViewColor(c4d.VIEWCOLOR_ACTIVEPOINT), True)
Best wishes
Martin
On 23/10/2014 at 07:24, xxxxxxxx wrote:
That helps. Now, to make it another color when highlighted.. I want it to work the way a Null does. Black lines then white when highlighted/selected. Heres what I got.
	def Draw(self, op, drawpass, bd, bh) :
		if drawpass==c4d.DRAWPASS_HIGHLIGHTS:
			bd.SetPen(c4d.Vector(1,1,1))
			return c4d.DRAWRESULT_SKIP
		data= op.GetDataInstance()
		size= c4d.Vector(25,0,25)
		mat = op.GetMg()
		box = c4d.Matrix()
		bd.SetPen(c4d.GetViewColor(c4d.VIEWCOLOR_ACTIVEBOX))
		bd.DrawBox(box, 1.0, c4d.GetViewColor(c4d.VIEWCOLOR_SHADEDWIRE), True)
		return c4d.DRAWRESULT_OK
On 23/10/2014 at 07:45, xxxxxxxx wrote:
you can use IsActive() and IsHighlight() to find out if the current object is selected or highlighted.
Best wishes,
Sebastian
On 23/10/2014 at 11:08, xxxxxxxx wrote:
Right. I can get it to like "print "Highlighted"". So I know when it's highlighted, but how can I change the color of the basedraw? Do I have to redraw it? Or just somehow change the pen color..
Thanks.
On 23/10/2014 at 12:09, xxxxxxxx wrote:
Hi Joe,
you can use a custom color definition like:
      pencolor = c4d.Vector(0,0,0)
      if bh.IsHighlight() :
          pencolor = c4d.Vector(1,1,1)
          print "highlight"
      if bh.IsActive() :
          pencolor = c4d.Vector(1,1,0)
          print "active"
      mat = op.GetMg()
      box = c4d.Matrix()
      bd.DrawBox(box, 1.0, pencolor, True)
or have a look at the c++ sdk
http://www.maxonexchange.de/sdk/Cinema4DR16SDK/html/group___v_i_e_w_c_o_l_o_r.html#ga59ce3d29b2ad9c9e57410cefd023adbb
Best wishes
Martin
On 23/10/2014 at 18:28, xxxxxxxx wrote:
Here's my code. If I have one object selected, I don't see the Active color, It appears as black. Highlight works though.
But, If I have multiple objects selected, they appear yellow (which is correct). Any ideas?
			pencolor = c4d.GetViewColor(c4d.VIEWCOLOR_OBJECTHIGHLIGHT)
		if bh.IsActive() :
			pencolor = c4d.GetViewColor(c4d.VIEWCOLOR_OBJECTSELECT)
		size= c4d.Vector(10,0,10)
		mat = op.GetMg()
		box = c4d.Matrix()
On 24/10/2014 at 02:47, xxxxxxxx wrote:
Hi Joe,
this works,
Just a better setup for the different cases with if and elif...
And you use the colors the user predefined in his preferences
      if drawpass==c4d.DRAWPASS_OBJECT:
          mat = node.GetMg()
          box = c4d.Matrix()
              pencolor=c4d.GetViewColor(c4d.VIEWCOLOR_SELECTION_PREVIEW)
          elif bh.IsActive() :
              pencolor=c4d.GetViewColor(c4d.VIEWCOLOR_ACTIVEPOINT)
              pencolor=c4d.GetViewColor(c4d.VIEWCOLOR_INACTIVEPOINT)
Best wishes
Martin
On 24/10/2014 at 05:58, xxxxxxxx wrote:
That did it! Thanks Martin
