R16 iterators [SOLVED]
  • On 21/10/2014 at 08:49, xxxxxxxx wrote:
    Cinema 4D Version:   R16
    Platform:   Windows  ;
    I'm having trouble with R16 iterators.
    I must first confess that I don't use iterators in C++ because I think it's very ugly looking code. But I would like to force myself to use them more often.
    This code yells at me that <BaseArray<Int> is not a template.
    I do have #include "c4d_misc.h" in my code. Do I need to write my own template?
    How do I make this work?
        maxon::BaseArray<Int> myarr;
      for (maxon::AutoIterator<BaseArray<Int> > it(myarr); it; ++it)
          //... do something with *it or it->
    Can someone also please post an example how to use an R16 iterator to iterate the objects in the hierarchy?
    Thanks,
  • On 21/10/2014 at 08:54, xxxxxxxx wrote:
    It's similar to the STD iterators.
    for (maxon::BaseArray<Int>::Iterator it = myarr.Begin(); it != myarr.End(); ++it)
    I prefer to use auto for iterators.
    for (auto it = myarr.Begin(); it != myarr.End(); ++it)
    There's also a FOREACH macro in the SDK. I think you use it like this
    FOREACH (it, myarr)
  • On 21/10/2014 at 09:59, xxxxxxxx wrote:
    Thanks Niklas.
    This is what I have working so far:
        //Create an array and fill it with some data
      for(Int32 i = 0; i < 10; i++){ myarr.Append(i); }
      //Iterate through the array using an iterator
      //The iterator 'it' is the value of each array element
      //for(maxon::BaseArray<Int>::Iterator it = myarr.Begin(); it != myarr.End(); ++it)
      for(auto it = myarr.Begin(); it != myarr.End(); ++it)
          auto value = *it;
          GePrint(String::IntToString(value));
          if (*it == 5) { GePrint("found value of 5"); break; }
      FOREACH(it, myarr)
          GePrint("ForEach macro results: " + String::IntToString(*it));
    Now I just need to figure out how to iterate objects.
    P.S. @ MAXON: Please document these things better with examples like the one I just posted
  • On 21/10/2014 at 10:09, xxxxxxxx wrote:
    What do you mean with "how to iterate objects"?
  • On 21/10/2014 at 10:38, xxxxxxxx wrote:
    Something like this:
          FOREACH(obj, MyAtomArray)
              GePrint(obj->GetName());
    I know how to do this with an AtomArray and a standard for() loop.
    But I'd like to use the new FOREACH and/or iterators instead.
  • On 21/10/2014 at 12:04, xxxxxxxx wrote:
    The AtomArray has no built-in iterator capabilities. You have to use GetIndex().
  • On 21/10/2014 at 12:11, xxxxxxxx wrote:
    Well. That's just an example.
    Is there no way to use the new iterators for iterating object hierarchies?
  • On 21/10/2014 at 12:13, xxxxxxxx wrote:
    Sorry, forget this post. I wasn't aware you were already a few steps further... :(
    Hi Scott,
    I'm not quite sure, as you seemed to already have it. Here's your example with PolygonObject:
    maxon::BaseArray<PolygonObject*> polyarr;
    for (Int32 i = 0; i < 10; i++) { polyarr.Append(PolygonObject::Alloc(8, 6)); }
    for (auto it = polyarr.Begin(); it != polyarr.End(); ++it) {
      auto pPObj = *it;
      GePrint(String::IntToString(pPObj->GetPolygonCount()));
      if (pPObj->GetPolygonCount() == 6) { GePrint("polyarr found possible cube"); break; }
    FOREACH(it, polyarr)
      GePrint("polyarr ForEach macro results: " + String::IntToString((*it)->GetPolygonCount()));
  • On 21/10/2014 at 12:36, xxxxxxxx wrote:
    Anyway, I'll add iterators on our ever growing todo list of documentation topics.
    Regarding your question: I don't think so (Niklas may correct me, if I'm mistaken). In order to use the iterator, the class to iterate needs to have one defined. Like BaseArray
  • On 24/10/2014 at 04:57, xxxxxxxx wrote:
    That's correct. Only the new array classes support iterators, the old ones don't. That's one of the many advantages the new classes have, and one more reason to use them whenever possible.
