Issue when opening a ASYNC sub-dialog [SOLVED]
  • On 20/10/2014 at 13:11, xxxxxxxx wrote:
    I have a ASYNC dialog. I want to be able to have a button open another ASYNC dialog as a sub dialog. Whenever I do, it makes the second one un-functional. Any button presses don't work.
    Anyone else seen this issue?
    Also, I would make it MODAL dialog. But it has to have a link box to drag an object to.
    Thanks,
    Joe
  • On 20/10/2014 at 16:26, xxxxxxxx wrote:
    Do you keep a reference to the dialog after opening it?
  • On 20/10/2014 at 20:05, xxxxxxxx wrote:
    No. I just want it to perform a task, then close. It just needs to be ASYNC.
  • On 20/10/2014 at 22:18, xxxxxxxx wrote:
    Well, you need to keep a reference, otherwise its being garbage collected
  • On 21/10/2014 at 06:18, xxxxxxxx wrote:
    Hmm.. Sample code would be a lot more helpful..
    Not too sure how to do this?
  • On 21/10/2014 at 09:47, xxxxxxxx wrote:
    simply add a member variable to the first dialog. This way the second dialog is owned and managed by the first GeDialog:
     **class DialogB(c4d.gui.GeDialog) :**
      def CreateLayout(self) :
          self.SetTitle("Dialog B")
          self.AddCustomGui(id=1001, pluginid=c4d.CUSTOMGUI_LINKBOX, name="Link", flags=c4d.BFH_LEFT, minw=200, minh=100)
          self.AddButton(id=1000,flags=c4d.BFH_LEFT,initw=100,inith=100,name="Close")
      def Command(self, id, msg) :
          if id == 1000:
              self.Close()
    **class DialogA(c4d.gui.GeDialog) :**
      dialog = None
          self.SetTitle("Dialog A")
          self.AddButton(1000,c4d.BFH_LEFT,200,100,"Open Dialog")
          if id == 1000:
              if self.dialog == None:
                  self.dialog = DialogB()
              self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=1000051, defaultw=400, defaulth=400)
    To use a link in a dialog you have to create a custom GUI element of the type CUSTOMGUI_LINKBOX. But you have to use a async dialog when you want to drag something into this link.
    best wishes,
    Sebastian
  • On 21/10/2014 at 11:56, xxxxxxxx wrote:
    Got it! I placed the dialog reference before the code. But I can change it to what you posted. Also, I want the main dialog (DialogA) to do something once DialogB closes. Any ideas with that?
    On a MODAL dialog, it waits. But with an ASYNC, it just runs through the rest of the code after DialogB opens..
    Thanks,
    Joe
  • On 22/10/2014 at 02:37, xxxxxxxx wrote:
    you could send a custom core message using SpecialEventAdd. Then you can listen for this message with GeDialog.CoreMessage.
    best wishes,
    Sebastian
  • On 22/10/2014 at 03:23, xxxxxxxx wrote:
    That's pretty much the idea behind asynchronous dialogs. They run in a different thread, not blocking
    the execution from which you open it.
  • On 22/10/2014 at 06:20, xxxxxxxx wrote:
    The SpecialEventAdd worked! Thanks Sebastian!
