Create Xref with python
  • On 18/10/2014 at 11:53, xxxxxxxx wrote:
    I've found a couple posts about this but no clear answers.
    https://plugincafe.maxon.net/topic/8036/10449_xref-python-command
    Is it possible to create an Xref object and pass in a file path using python rather than just opening the dialog to search for it? If so, does someone have a code snippet they can share?
    EDITED:
    I've got this going so far, but the filepath isn't updating. I guess maybe I need to load a file into the Xref object?
    def main() :
        op = c4d.BaseObject(c4d.Oxref)
        rocket = "/component1.c4d"
        op.GetObjectLink(rocket)
        op[c4d.ID_CA_XREF_FILE_SELECT] = "component1.c4d"
        op[c4d.ID_CA_XREF_NAMESPACE] = "rocket"
        op[c4d.ID_CA_XREF_GENERATOR] = 1
        box = c4d.BaseObject(c4d.Ocube)
        box.SetName("new")
        doc.InsertObject(box)
        doc.InsertObject(op)
  • On 20/10/2014 at 00:59, xxxxxxxx wrote:
    Due to some limitations it is currently not possible to set the filename parameter of a Xref object in Python.
    Best wishes,
    Sebastian
  • On 21/10/2014 at 08:43, xxxxxxxx wrote:
    Any idea of when this will be fixed?
  • On 21/10/2014 at 09:59, xxxxxxxx wrote:
    Sorry, I don't know when this will be fixed.
