Datatype and Nodes
On 15/11/2002 at 10:27, xxxxxxxx wrote:
Cinema 4D Version:   8.012
Platform:      Mac OSX  ;
How do you use a custom data type with node. Explicitely how would I insert the examle datatype into a res file for a node so that it is a parameter? If I try putting in a port of type CUSTOMDATATYPE_EXAMPLE, or 123123123, I get an error reading the res file for the node in Xpresso.
On 17/11/2002 at 09:06, xxxxxxxx wrote:
You should use the string returned by CustomDataTypeClass::GetResourceSym() in resource files, for example "ExampleDataType".
