On 08/10/2014 at 04:19, xxxxxxxx wrote:
Hallo,
in this script ( c4d file https://www.hidrive.strato.com/share/mvm9t4h3vi#$/) i want to deselect a number of selected polygons but the editor is not refreshed.
import c4d #Welcome to the world of Python
def main() : # global changed # must be defined in function as global # null=op.GetObject() # object of python tag print " " obj=doc.GetActiveObject() if not (obj==None) : print "selected object =",obj.GetName(), obj.GetTypeName() if (obj.CheckType(c4d.Opolygon)) : n=obj.GetPolygonCount() sel=obj.GetPolygonS() nsel=sel.GetCount() nth=op[c4d.ID_USERDATA,1] print "number of selected polygons:",n,nsel,nth if (nsel>3) : for i in range(0,nsel) : if (i % nth==0) : sel.Deselect(i) print i,"deselected" # here i want to refresh the editor # c4dtools.utils.update_editor() # nothing happens # obj.Message(c4d.MSG_UPDATE) # nothing happens # c4d.EventAdd(); # endless loop calling this function return
I have googleing one day without any result. Please excuse me its my first posting in forums.
Thanks Udo Welz
On 08/10/2014 at 08:24, xxxxxxxx wrote:
Welcome.
Try it like this:
import c4d def main() : #The object the tag is on obj = op.GetObject() if not obj: return False totalpolys = obj.GetPolygonCount() PolyS = obj.GetPolygonS() #If the user selects 4 or more polygons #The code below will automatically de-select every other polygon if PolyS.GetCount() > 3: #We will De-Select every other polygon #Change this variable. Or use a UserData gizmo to change it nth = 2 #First this code selects all of the polygons #Then it de-selects every other one for poly in xrange(totalpolys) : PolyS.Select(poly) if poly % nth==0: PolyS.Deselect(poly)
On 09/10/2014 at 04:12, xxxxxxxx wrote:
Thank you ScottA.
It's my first test in programming cinema. My goal is to select a bunch of polygons in editor e.g. like the loop selection on sphere. Then run the script to deselect nth polygon. Then i want to continue modelling with this selection in editor. I thought that sel is an array or so and the loop index e.g. 2 selected the 2.th selected polygon but it's only selecting the 2.th polygon of all polygons wich was not select. Sorry for my english. I am german and speaking or writting is not so good. Your suggestion was very helpful.
Udo
On 09/10/2014 at 05:10, xxxxxxxx wrote:
I've solved this problem by doing this
import c4d import new #Welcome to the world of Python
def main() : # global changed # must be defined in function as global # null=op.GetObject() # object of python tag if (op!=doc.GetActiveTag()) : return print " " obj=doc.GetActiveObject() if not (obj==None) : print "selected object =",obj.GetName(), obj.GetTypeName() if (obj.CheckType(c4d.Opolygon)) : n=obj.GetPolygonCount() sel=obj.GetPolygonS() nsel=sel.GetCount() nth=op[c4d.ID_USERDATA,1] print "number of selected polygons:",n,nsel,nth if (nsel>3) : j=0 for i in xrange(n) : if (sel.IsSelected(i)) : if (j % nth==0) : sel.Toggle(i) print i,"deselected" j+=1
Thank you ScottA for help
