On 05/10/2014 at 03:07, xxxxxxxx wrote:
I have a tag plugin that works correctly if I drag the tag to an object.
However, when I save the scene with an object with the tag on it, the next time I open this previous save scene, the userdata is not correct.
I get the below message in the console.
The userdata is there, I can also see it, but it is not working properly.
It is not "recognized" by the plugin.
class UDTest(plugins.TagData) :
def Init(self, node) :
print "Init........................."
print "Init Len(ud) : ", len(node.GetUserDataContainer())
def Execute(self, tag, doc, op, bt, priority, flags) :
print "Execute Len(ud) : ", len(tag.GetUserDataContainer())
if (len(tag.GetUserDataContainer()) == 0) : #Only init userdata when there is no userdata
bakeMessage = CreateUserDataStaticText(tag, "Message", "")
self.BAKEMESSAGE = bakeMessage[1].id
clearBakeMessage = CreateUserDataBool(tag, "Clear", val=False)
self.CLEARBAKEMESSAGE = clearBakeMessage[1].id
#Clear bake message field
if (tag[c4d.ID_USERDATA, self.CLEARBAKEMESSAGE]) :
tag[c4d.ID_USERDATA, self.CLEARBAKEMESSAGE] = False
tag[c4d.ID_USERDATA, self.BAKEMESSAGE] = ""
bmp = bitmaps.BaseBitmap()
dir, file = os.path.split(__file__)
bitmapfile = os.path.join(dir, "res", "Icon.tif")
#print bitmapfile
result = bmp.InitWith(bitmapfile)
if not result:
print "Error loading bitmap!"
okyn = plugins.RegisterTagPlugin(id=PLUGIN_ID, str="UDTest v01", info=c4d.TAG_VISIBLE|c4d.TAG_EXPRESSION, g=UDTest, description="", icon=bmp)
print "UDTest initialized, v01: ", okyn
