On 01/10/2014 at 15:13, xxxxxxxx wrote:
I'm writing a plugin and need an ASYNC dialog. I tried using ScrollGroupBegin but it only scrolls when my dialog type is MODAL. Whats up with that? Is there not a way to use it with an ASYNC dialog? I need to be able to dock my plugin.
On 01/10/2014 at 16:07, xxxxxxxx wrote:
It should work fine with async dialogs. I've used it in my poselibrary plugins.
Here's a very quick and dirty script manager example. When I dock the dialog above the OM. The bottom scroll bar appears as expected.
import c4d class Dialog(c4d.gui.GeDialog) : def CreateLayout(self) : flags = c4d.SCROLLGROUP_HORIZ | c4d.SCROLLGROUP_VERT if self.ScrollGroupBegin(0, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, flags, 100, 100) : self.AddButton(1000, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT,600,50) self.GroupEnd() return True def Command(self, id, msg) : if id == 1000: self.LayoutChanged(1000) return True dlg = Dialog() dlg.Open(c4d.DLG_TYPE_ASYNC)
