Add a combobox userdata using python
On 26/09/2014 at 11:47, xxxxxxxx wrote:
How can I add a userdata combobox using python?
Define a long and adding children to it does not work.
bc = c4d.GetCustomDatatypeDefault(c4d.DTYPE_LONG) # Create default container bc[c4d.DESC_NAME] = "Point" # Rename the entry element1 = node.AddUserData(bc) # Add userdata container node[element1] = 2 # Assign a value #DTYPE_CHILDREN bc = c4d.GetCustomDatatypeDefault(c4d.DTYPE_CHILDREN) # Create default container bc[c4d.DESC_NAME] = "Name 01" # Rename the entry element11 = node.AddUserData(bc) # Add userdata container node[element11] = "Name 01" # Assign a value
On 26/09/2014 at 13:45, xxxxxxxx wrote:
import c4d def main() : obj = doc.GetActiveObject() if not obj: return False #This code block creates a ComboButton type button gizmo cbgizmo = c4d.GetCustomDataTypeDefault(c4d.DTYPE_LONG) cbgizmo[c4d.DESC_NAME] = "My Combo" cbgizmo[c4d.DESC_CUSTOMGUI] = c4d.CUSTOMGUI_CYCLE #Create a list of names and put them into a container names = c4d.BaseContainer() names.SetString(0,"Scott") names.SetString(1,"Jim") names.SetString(2, "Jane") cbgizmo.SetContainer(c4d.DESC_CYCLE, names) entries = op.AddUserData(cbgizmo) #This sets the ComboButton to the second entry by default("Jim") #Because you might not want the first entry to be the default op[entries] = 1 c4d.SendCoreMessage(c4d.COREMSG_CINEMA, c4d.BaseContainer(c4d.COREMSG_CINEMA_FORCE_AM_UPDATE)) c4d.EventAdd() if __name__=='__main__': main()
On 27/09/2014 at 00:50, xxxxxxxx wrote:
Great, thank you.
And I guess, adding or changing the list of names is then just using
BaseList2D.SetUserDataContainer
On 27/09/2014 at 07:31, xxxxxxxx wrote:
Edit or add things to the "names" BaseContainer() to change the things in the list.
SetUserDataContainer() updates the UD after you've changed something inside it.-ScottA
