Replacement for AttachImage()?
On 12/11/2002 at 16:23, xxxxxxxx wrote:
Cinema 4D Version: 8.012
Is there a replacement method for AttachImage() in GeDialog? Is the only method now to subclass GeUserArea and use a BaseBitmap?
Do you expect all plugins to switch to using the Attributes manager rather than utilizing one's own dialog? I found that MSG_GETDESCRIPTION no longer exists for Message(). Does this mean that one must use the new description parameters to be able to animate variables?
Thank you,
Jane
On 13/11/2002 at 00:13, xxxxxxxx wrote:
This is now handled by BitmapButtonCustomGui. Though none of the SDK example demonstrate it, you can see an example in filterpreview.cpp line 1024.
These custom GUIs will hopefully be covered by the next documentation update.
By all means this is recommended once you port your plugin to the R8 API. Almost all dialogs within C4D has been replaced by simple description resources for the Attributes Manager.
Yes, the old description system is no longer supported.
If you have question about how to best convert your dialog to a description resource you're more than welcome to ask here. Personally I had to do this for the upcoming MSA 3.0 and Helix 3.0 and found it was much less work than expected. The descriptions offer less layout capatibilities, but this is also liberating since you can focus more on how the parameters are structured.
And the conversion is very rewarding. Once your parameter description is in place you can immediately start using Xpresso to manipulate parameters within your plugin. At least I got a kick out of this... :-)
