Copy texture and save it as png?
On 16/09/2014 at 13:37, xxxxxxxx wrote:
Hello mates..
im woundering how i can take a mat/texture (psd) file and copy it and save it as example *.png.
is this possible with python?
On 22/09/2014 at 04:48, xxxxxxxx wrote:
you can load the texture file into a BaseBitmap and then save that BaseBitmap as a PNG. The following code assumes you are using a Mmaterial:
     #get the active material
     activeMaterial = doc.GetActiveMaterial()
      if activeMaterial != None:
          colorShader = activeMaterial[c4d.MATERIAL_COLOR_SHADER]
          if colorShader != None:
              if colorShader.GetType() == c4d.Xbitmap:
                  # get the texuture file
                  bitmapPath = colorShader[c4d.BITMAPSHADER_FILENAME]
                  # load the texture file into the BaseBitmap
                  theBitmap = bitmaps.BaseBitmap()
                  theBitmap. _ **InitWith**_ (bitmapPath)
                  # get the path / filename to save
                  savePath = c4d.storage.SaveDialog(c4d.FILESELECTTYPE_IMAGES,"Save as PNG")
                  # save
                  res = theBitmap. ** _Save_** (savePath, ** _c4d.FILTER_PNG_** )
                  if res != c4d.IMAGERESULT_OK:
                      print("Error saving the bitmap!")
best wishes,
Sebastian
On 22/09/2014 at 08:29, xxxxxxxx wrote:
Thank you.
I was about to start messing around with PIL. seems like i dont need to do that anymore. :)
