On 05/09/2014 at 03:04, xxxxxxxx wrote:
I want to simplify the timeline by seeing just one track. For example the animated x-coordinate track. I can do that by selecting the track and then do a "Hide Unselected Elements".
So, to hide all other ctracks, I need to select the ctrack first. But I do not know how to select a track in the timeline?
I can find the track and get all values, but selecting the track (highlight it) I do not know how. When the track is selected I can do a c4d.CallCommand(465001055) # Hide Unselected Elements
-Pim
On 08/09/2014 at 05:48, xxxxxxxx wrote:
Still do know how to select a timeline track.
A workaround is to use layers and the layer manager. So, set the tracks you want to isolate on a separate layer and all others on a different layer. Then solo that layer.
On 08/09/2014 at 07:41, xxxxxxxx wrote:
To get & select the tracks in the timeline use GetNBit() and ChangeNBit()
import c4d def main() : obj = doc.GetActiveObject() if obj is None: return False Ztrack = obj.FindCTrack(c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_REL_POSITION,c4d.DTYPE_VECTOR,0), c4d.DescLevel(c4d.VECTOR_Z,c4d.DTYPE_REAL,0))) if Ztrack: #Get the value of the Z track's selection bit bit = Ztrack.GetNBit(c4d.NBIT_TL1_SELECT) #This will select the object's Z track if it's not currently selected if bit == 0: Ztrack.ChangeNBit(c4d.NBIT_TL1_SELECT, c4d.NBITCONTROL_SET) #If the track is aleady selected this code will execute if bit == 1: print "The Z track is selected" c4d.EventAdd() if __name__=='__main__': main()
On 09/09/2014 at 03:58, xxxxxxxx wrote:
Great, exactly what I'm looking for! It also tells me how to init DescId.
I did it directly in FindCTrack: #position = c4d.DescID([c4d.ID_BASEOBJECT_REL_POSITION,c4d.VECTOR_Z]) #not working??? atrack = op.FindCTrack([c4d.ID_BASEOBJECT_REL_POSITION,c4d.VECTOR_Z])
Pim
