On 02/09/2014 at 08:15, xxxxxxxx wrote:
Is it possible to add and subtract frames from a running render?
For example: Rendering from 1-200 but would like to add frames 201-210 rather than adding it to the render queue.
Thanks,
-Shawn
On 02/09/2014 at 13:11, xxxxxxxx wrote:
do you want do change a currently running render task? I don't think that's possible. But if you want to render certain frames without using the default options you may use RenderDocument.
Best wishes, Sebastian
On 02/09/2014 at 15:00, xxxxxxxx wrote:
Thanks for replying S_Bach,
Correct I am trying to access and change the end frames of the currently running render. The main goal is to evenly distribute frames among the render farm using a custom "Net Render."
I use a combination of RenderDocument and the send to picture viewer command, depending on the users preference.
