Quit Cinema4D
On 29/08/2014 at 05:15, xxxxxxxx wrote:
Cinema 4D Version:   13.061
Platform:   Windows  ;
Exist an message or hook function, which will be called before C4D closed ?
My problem if the user press the "Quit" menu entry or press in the upper right corner on the red field to quit C4D, I have to clean up some settings.
Or exist an possibility to prohibit the "quit" of the tool?
regards
On 29/08/2014 at 06:21, xxxxxxxx wrote:
Howdy,
Cleanup is usually done in the various Free() functions that are in the data classes. Plus, there is also the main PluginEnd() function that you might use.
Adios,
Cactus Dan
On 31/08/2014 at 23:47, xxxxxxxx wrote:
thanks for this hints. But I need a function call, before an C4D project will be closed.
regards
Marky
On 01/09/2014 at 03:15, xxxxxxxx wrote:
How about MSG_DOCUMENTINFO? I think  that this message is only sent to SceneHooks,
but I am not absolutely sure. The MSG_DOCUMENTINFO_TYPE_REMOVE type might be what
you want.
Best,
-Niklas
On 01/09/2014 at 05:27, xxxxxxxx wrote:
Howdy,
The documentation says it is sent as a broadcast message. I'm assuming that means it is sent to everything? I've used it in a ToolData::Message() function, so it doesn't seem to be confined to a SceneHook. 😉
Adios,
Cactus Dan
