Create Ngon with variable sides count [SOLVED]
On 21/08/2014 at 23:06, xxxxxxxx wrote:
Cinema 4D Version:   15
Platform:
Hi, I can create Ngons fine with the example from the SDK. The question is, how can I create an Ngon with a user controlled number of points.
//Generate N-Gon
int mySides = 7; //this is a dynamic value, and therefore cannot be used with padr
AutoAlloc<PolygonObject> obj(0,0);
if (!obj) return FALSE;
AutoAlloc<Modeling> mod;
if (!mod || !mod->InitObject(obj)) return FALSE;
//Create a circular point array
maxon::BaseArray<Int32>myPoints; Matrix m;
for (int i=0; i<mySides; i++)
	m = MatrixRotY(Rad(i*360/ mySides));
	int temp = mod->AddPoint(obj, m*Vector(100,0,0));
	myPoints.Append(temp);
Int32 padr[] = {-1, -2, -3, -4, -5, -6, -7}; // I want padr to use mySides for its size!!
Int32 cnt = mySides;
Int32 i = mod->CreateNgon(obj, padr, cnt);
if (!i) return FALSE;
if (!mod->Commit()) return FALSE;
doc->InsertObject(obj.Release(), NULL, NULL);
EventAdd();
Please excuse the r15 code style 🙂
On 21/08/2014 at 23:19, xxxxxxxx wrote:
Int32 *padr = new Int32[mySides];
if(padr) { delete padr; padr = NULL}
On 21/08/2014 at 23:58, xxxxxxxx wrote:
Thanks a lot Mohamed. It works.
On 22/08/2014 at 00:20, xxxxxxxx wrote:
glad that it worked
don't forget to delete the pointer once you finish working with it (or it will create a memory leak), read more about heap memory in C++ on stackoverflow "google is your friend"
On 22/08/2014 at 01:21, xxxxxxxx wrote:
I did, thanks!
A follow up question if you don't mind. I need to assign a different material tag (plus restriction and projection) to that created Ngon.
With regular polygons, I use this, where ret is the returned generator object:
	BaseTag* t = NULL;
	t = (static_cast<BaseTag*>(tex->GetClone(COPYFLAGS_0, NULL)));  //get a copy of the texture tag defined in Init
	ret->InsertTag(t);
	sT = SelectionTag::Alloc(Tpolygonselection);  //defined as a class variable
	ret->InsertTag(sT);
	sT->SetName("Selected Polygons 0");
BaseSelect* bs = sT->GetBaseSelect();
	bs->SelectAll(0,10);	    //selecting forst 11 polygons
	t->SetParameter(DescID(TEXTURETAG_RESTRICTION), GeData(sT->GetName()), DESCFLAGS_SET_0);
	t->SetParameter(DescID(TEXTURETAG_PROJECTION),  GeData(TEXTURETAG_PROJECTION_UVW), DESCFLAGS_SET_0);
Now how can I do this for the Ngon?
On 22/08/2014 at 01:30, xxxxxxxx wrote:
I'm not sure how it works "still my experience with the SDK near 0"
but I think this line:
bs->SelectAll(0,10);     //try to select last polygon
On 22/08/2014 at 08:36, xxxxxxxx wrote:
I just read the Ngons do not support UVs, so using them is moot.
I would have to build the cap manually with regular polygons and tris.
On 22/08/2014 at 10:37, xxxxxxxx wrote:
I guess you can triangulate the NGons and use this, there must be a way to work with them similar to polygon containers
On 22/08/2014 at 17:08, xxxxxxxx wrote:
Yes, underneath, NGons are 'collections of polygon edges'.  So, you will need to get the underlying polygons to work on the UVs.  PolygonObject has a method, GetNGonTranslationMap() which will return a set of polygon indices.  The NGon stuff is a bit complicated and there are several underlying classes, such as Pgon, to go between NGons and polygons.
