On 02/08/2014 at 07:13, xxxxxxxx wrote:
User Information: Cinema 4D Version: 14, 15 Platform: Windows ; Language(s) : C++ ;
--------- I am having trouble getting cycle buttons to work in a generator plugin. This is what I added in the res file
LONG MYOBJECT_CYCLE { CYCLE { CYCLE_ITEM_1; CYCLE_ITEM_2; CYCLE_ITEM_3; } }
The cycle list appears fine in the AM. The problem is when I am try to access the buttons. This is the code that I am using:
Bool MYOBJECT::Message(GeListNode *node, LONG type, void *data) { switch (type) { case MSG_DESCRIPTION_COMMAND: { DescriptionCommand *dc = (DescriptionCommand* ) data; if (dc->id[0].id == MYOBJECT_CYCLE) { BaseContainer *bc = ((BaseObject* )node)->GetDataInstance(); if (!bc) return FALSE; LONG item = bc->GetLong(MYOBJECT_CYCLE); switch (item) { case CYCLE_ITEM_1: GePrint("1"); break; case CYCLE_ITEM_2: GePrint("2"); break; case CYCLE_ITEM_3: GePrint("3"); break; default: GePrint("default"); break; } } } } return TRUE; }
Nothing gets printed. If I try to print dc- >id[0].id I don't get anything.I am presuming that MYOBJECT_CYCLE is not getting recognized in the first place. Anyone can shed a light on what I might be doing wrong?
Thanks
On 02/08/2014 at 10:54, xxxxxxxx wrote:
MSG_DESCRIPTION_COMMAND only works with Buttons. You should check using MSG_DESCRIPTION_CHECKUPDATE.
case MSG_DESCRIPTION_CHECKUPDATE: DescriptionCheckUpdate* dcu = static_cast<DescriptionCheckUpdate*>(data); if (!dcu) return TRUE; BaseContainer* bc = op->GetDataInstance(); if (!bc) return TRUE; LONG id = (*(dcu->descid))[0].id; LONG item = ... ...
On 02/08/2014 at 11:51, xxxxxxxx wrote:
Works like a charm. Thanks a lot (again) Robert!
