On 20/07/2014 at 15:20, xxxxxxxx wrote:
User Information: Cinema 4D Version: R15 Platform: Windows ; Mac OSX ; Language(s) : C++ ;
--------- Thought the ID would be M_PLUGINS like the custom menu example that uses M_EDITOR. Run through a few of the plugin ids in the symbols file but haven't found it.
Anyone know the id of the plugin menu off hand?
Ama
On 20/07/2014 at 16:20, xxxxxxxx wrote:
Just off the top of my head but if you do something like:
BaseContainer *pluginsMenu = SearchPluginMenuResource(); # Get 'Plugins' main menu resource LONG *menuID = pluginsMenu->GetId(); # Get id of menu basecontainer GePrint(LongToString(menuID));
Or something along those lines you should be able to get the ID of the menu container.. I think it would have to be done inside the C4DPL_BUILDMENU pluginmessage..
On 21/07/2014 at 06:05, xxxxxxxx wrote:
It's IDS_EDITOR_PLUGINS and is inside the M_EDITOR menu container.
Best, -Niklas
On 21/07/2014 at 06:13, xxxxxxxx wrote:
Thank you both!
Now that I have the menu I want to place my menu in the plugins list. Right now I get the second index in the plugin menu container and insert after it ( the separator ). Seems like this could be an issue in the future. I could search for the separator and place after that but that is still making some bad assumptions.
Any ideas?
thank you, Ama
On 21/07/2014 at 16:04, xxxxxxxx wrote:
Prob either search for the last thing in the menu container or search for the last separator ( whatever works ) and insert after that?
Heres how the SDK examples does the menu insert in Main.cpp ( in case its useful and you havent seen it ). Theres also a good example somewhere in the python docs i cant find:
void EnhanceMainMenu(void) { // do this only if necessary - otherwise the user will end up with dozens of menus! BaseContainer *bc = GetMenuResource(String("M_EDITOR")); if (!bc) return; // search for the most important menu entry. if present, the user has customized the settings // -> don't add menu again if (SearchMenuResource(bc,String("PLUGIN_CMD_1000472"))) return; GeData *last = SearchPluginMenuResource(); BaseContainer sc; sc.InsData(MENURESOURCE_SUBTITLE,String("SDK Test")); sc.InsData(MENURESOURCE_COMMAND,String("IDM_NEU")); // add C4D's new scene command to menu sc.InsData(MENURESOURCE_SEPERATOR,TRUE); sc.InsData(MENURESOURCE_COMMAND,String("PLUGIN_CMD_1000472")); // add ActiveObject dialog to menu if (last) bc->InsDataAfter(MENURESOURCE_STRING,sc,last); else // user killed plugin menu - add as last overall entry bc->InsData(MENURESOURCE_STRING,sc); } Bool PluginMessage(LONG id, void *data) { switch (id) { case C4DPL_BUILDMENU: //react to this message to dynamically enhance the menu EnhanceMainMenu(); break; } }
On 22/07/2014 at 00:17, xxxxxxxx wrote:
Originally posted by xxxxxxxx Theres also a good example somewhere in the python docs i cant find:
The example in the Python documentation can be found at the page "Plugin Structure" and section "Enhancing the Main Menu".
