View Settings
On 18/07/2014 at 06:59, xxxxxxxx wrote:
Hello!
I'm trying to write a script which can change some view settings automatically.
What I need: I need to change projection settings to "Front view" and make it "used as render view".I was able to make the first part work:
data = doc.GetActiveBaseDraw()
data[c4d.BASEDRAW_DATA_PROJECTION] = 4But I've got no idea how to make the second part work. Please Help ME! =)
On 18/07/2014 at 07:43, xxxxxxxx wrote:
You could use a call Command.
c4d.CallCommand(13931) # Use as Render View
On 18/07/2014 at 07:51, xxxxxxxx wrote:
Thank you! I think it will work.
But I've got one more queation: is there a list of all command IDs?
On 18/07/2014 at 08:20, xxxxxxxx wrote:
Shift + F12
Then click on an entry and you see the command id below
On 18/07/2014 at 08:25, xxxxxxxx wrote:
Thank you guys!
You've sorted my problem out!
