On 10/07/2014 at 11:34, xxxxxxxx wrote:
I am trying to get all of the shaders that are in a material.
This returns some of the shaders but not all of them. I am using it on an Octane material but that shouldn't make a difference. Drag and dropping my material into the timeline will show all of the shaders, basically I want that list.
Here is the code: Just a simple search down and next script. Any help would be great!
import c4d,sys from c4d import gui def main() : c4d.CallCommand(13957) def ShaderSearch(shader) : next = shader.GetNext() down = shader.GetDown() print shader.GetName() if down: ShaderSearch(down) if next: ShaderSearch(next) shader = doc.GetActiveMaterial().GetFirstShader() ShaderSearch(shader) c4d.EventAdd() if __name__=='__main__': main()
On 10/07/2014 at 12:08, xxxxxxxx wrote:
I figured it out, I had to treat each shader like a separate object. simple addition, heres the code:
import c4d,sys from c4d import gui def main() : c4d.CallCommand(13957) ShaderList[] def ShaderSearch(shader) : next = shader.GetNext() down = shader.GetDown() try: ShaderSearch(shader.GetFirstShader()) except AttributeError: pass print shader.GetName() if down: ShaderSearch(down) if next: ShaderSearch(next) shader = doc.GetActiveMaterial().GetFirstShader() ShaderSearch(shader) c4d.EventAdd() if __name__=='__main__': main()
