On 06/07/2014 at 22:19, xxxxxxxx wrote:
User Information: Cinema 4D Version: 14 Platform: Windows ; Language(s) :
--------- Hi I am creating a BaseArray: c4d_misc::BaseArray<Vector> MyVectorArray
If I try to pass it to a function, the compiler throws an error: 'c4d_misc::BaseArray<T>::BaseArray' : cannot access private member declared in class 'c4d_misc::BaseArray<T>'
I can pass a GeDynamicArray to a function without problems, but I would like to use BaseArray for its speed.
So basically, how do I pass a BaseArray to a function.
On 08/07/2014 at 12:57, xxxxxxxx wrote:
No hint on passing a BaseArray to a function?
c4d_misc::BaseArray<Vector> MyVectorArray; MyVectorArray.Resize(10); for (int i=0; i<10; i++) MyVectorArray[i] = Vector(0,i,0); GePrint(RealToString(MyVectorArray[5].y)); //5 This works!!! printVectorBaseArray(MyVectorArray); //DOES NOT WORK....BaseArray is Inaccessible!!! void printVectorBaseArray(c4d_misc::BaseArray<Vector> inputVectorArray) { GePrint(RealToString(inputVectorArray[5].y)); }
On 08/07/2014 at 13:51, xxxxxxxx wrote:
It protects you from passing the array by value, which is what you are doing. The function call would require to copy the whole array. Pass it as a pointer or reference (usually preferred).
void printVectorBaseArray(c4d_misc::BaseArray<Vector> **&** inputVectorArray) { GePrint(RealToString(inputVectorArray[5].y)); }
-Niklas
On 08/07/2014 at 15:18, xxxxxxxx wrote:
It works. Thanks Niklas!
On 09/07/2014 at 08:19, xxxxxxxx wrote:
But please do not forget about const if the array do NOT need to be modified inside function.
void printVectorBaseArray( **const** c4d_misc::BaseArray<Vector> **&** inputVectorArray) { GePrint(RealToString(inputVectorArray[5].y)); }
On 09/07/2014 at 11:18, xxxxxxxx wrote:
That's a good tip, thanks Remo!
