On 04/07/2014 at 02:57, xxxxxxxx wrote:
I like to check using a plugin or a script, whether the object has changed. IsDirty is not giving me any information, so I use GetDirty and check whether that value has changed. That is ok when in Model mode, but when in Polygon mode, the value returned by GetDirty is not changed when I move a polygon? DIRTY_MATRIX and the others are all returning the same value.
How to check whether a polygon has moved, scaled or rotated?
import c4d from c4d import gui def main() : obj = doc.SearchObject("Cube") print "--- IsDirty ---" print "Get DIRTY_MATRIX", obj.GetDirty(c4d.DIRTY_MATRIX) print "Get DIRTY_SELECT: ", obj.GetDirty(c4d.DIRTY_SELECT) print "Get DIRTY_CACHE: ", obj.GetDirty(c4d.DIRTY_CACHE) print "Get DIRTY_CHILDREN: ", obj.GetDirty(c4d.DIRTY_CHILDREN) if __name__=='__main__': main()
On 04/07/2014 at 04:54, xxxxxxxx wrote:
IsDirty() should be used for Generator plugins only. You know there is another one, DIRTYFLAGS_DATA, right? This one is changed when the polygons or points changed of an object.
Best, -Niklas
