Place an Objet with obj.SetMg(m)
  • On 04/07/2014 at 00:35, xxxxxxxx wrote:
    I want to place an Object on a given global Koordinate.
    What i have is a Matrix with 16 Values like:
    "1,0,0,0,0,1,0,0,0,0,1,0,0,0,5,1.439"
    I read the documentation and found in the Topic "Matrix Fundamentals"
    that my matix is like this:
          1     0     0     0      1     0     0     0
        v0.x v1.x v2.x v3.x     0     1     0     0
    m = v0.y v1.y v2.y v3.y = 0     0     1     0
        v0.z v1.z v2.z V3.z     0     0     1   1.439
    Here my question:
    How can I convert my Data-Structure so, that i can write it in the command
    obj.SetMg(Matrix)
    here my aktual code
    coord = LINEDATA.split(",")
                        #print coord
                        #print ("Datenzeile enthält " + str(len (coord)) + " Datensätze")
                        MA1 = float(coord[0])
                        MA2 = float(coord[1])
                        MA3 = float(coord[2])
                        MA4 = float(coord[3])
                        MA5 = float(coord[4])
                        MA6 = float(coord[5])
                        MA7 = float(coord[6])
                        MA8 = float(coord[7])
                        MA9 = float(coord[8])
                        MA10 = float(coord[9])
                        MA11 = float(coord[10])
                        MA12 = float(coord[11])
                        MA13 = float(coord[12])
                        MA14 = float(coord[13])
                        MA15 = float(coord[14])
                        MA16 = float(coord[15])
                        Matrix = [[MA1,MA2,MA3,MA4],[MA5,MA6,MA7,MA8],[MA9,MA10,MA11,MA12],[MA13,MA14,MA15,MA16]]
                        print Matrix
                        #c4d.SetPoint(i,c4d.Vector(x,y,z))
                        obj = c4d.BaseObject(c4d.Onull)        # Create new cube
                        #obj.SetRelPos(c4d.Vector(20))           # Set position of cube
                        obj.SetMg(Matrix)
                        doc.InsertObject(obj)                   # Insert object in document
    Thanks a lot
  • On 04/07/2014 at 03:12, xxxxxxxx wrote:
    Why don't you use the given function in that matrix chapter:
    You only need to define v0 - offset and v1,v2,v3 - scale and rotation.
    E.g. SetGlobalScale(obj, c4d.Vector(1.0, 1.0, 1.439))
    SetGlobalPosition(obj, pos) # Sets the global position of obj to pos
    SetGlobalRotation(obj, rot) # Sets the global rotation of obj to rot
    SetGlobalScale(obj, scale)  # Sets the global scale of obj to scale
  • On 04/07/2014 at 05:31, xxxxxxxx wrote:
    it sounds so easy
    but:
    how do I define v_0 (i think this is the offset
    how do I define v_1
    how do I define v_2
    how do I define v_3
    how do I define pos
    how do I define rot
    how do I define scale
    I know it is in my linedata
    here an example: "1,0,0,0,0,1,0,0,0,0,1,0,0,0,5,1.439"
    But i dont know how to convert it.
    Sorry for sutch stupid questions
    Here is my actual code
    for line in DATA:
        LINEDATA = line.strip()                    #lese den Zeileninhalt ohne rechte Leerzeichen
        if (LINEDATA.find (SUCHSTRING_DATA) != -1) :
            l = len(SUCHSTRING_DATA)
            LINEDATA = LINEDATA[l:]
            LINEDATA = LINEDATA[:-4]
            print "Begin neuer Datensatz"
            # Umwandlung in floating
            for i in range(16) :
                coord[i] = float(coord[i])
                #print ("Coord", i , "= ",coord[i])
                #print i
                continue
            print (coord)
            # Definition der Vektoren
            v_1 = c4d.Vector( coord[5] , coord[9] , coord[13] )
            v_2 = c4d.Vector( coord[6] , coord[10] , coord[14] )
            v_3 = c4d.Vector( coord[7] , coord[11] , coord[15] )
            off = c4d.Vector(0,0,0)
            print ( v_1 , v_2 , v_3, off)
            print ()
            print (v_1)
            print (v_2)
            print (v_3)
            print (off)
            mat = (v_1,v_2,v_3,off)
            obj = c4d.BaseObject(c4d.Onull)        # Create new nullobject
            obj.SetMg(mat)
  • On 04/07/2014 at 07:01, xxxxxxxx wrote:
    Looks good.
    But make
    mat = c4d.Matrix(off, v_1, v_2, v_3)
    instead.
  • On 04/07/2014 at 07:15, xxxxxxxx wrote:
    Jipiayay
    small change, big impact.
    it works.
    Thanks a lot
