On 26/06/2014 at 02:31, xxxxxxxx wrote:
--------- I am creating a generator plugin and setting up a basic object hierarchy within my GetVirtualObjects override as follows:
BaseObject* MyGenerator::GetVirtualObjects(BaseObject* op, HierarchyHelp* hh) { Bool dirty = op->CheckCache(hh) || op->IsDirty(DIRTYFLAGS_DATA); if (!dirty) return op->GetCache(hh); //// NULL //// BaseObject *groupNull = BaseObject::Alloc(Onull); //// CUBE //// BaseObject *cube = BaseObject::Alloc(Ocube); BaseContainer *cubeData = cube->GetDataInstance(); cubeData->SetBool(PRIM_CUBE_DOFILLET, TRUE); cubeData->SetLong(PRIM_CUBE_SUBF, 1); cubeData->SetReal(PRIM_CUBE_FRAD,10); cubeData->SetLong(PRIM_CUBE_SUBX, 20); cubeData->SetLong(PRIM_CUBE_SUBY, 8); cubeData->SetLong(PRIM_CUBE_SUBZ, 50); cubeData->SetVector(PRIM_CUBE_LEN, Vector(200,80,500)); //// HYPERNURBS //// BaseObject *hN = BaseObject::Alloc(Osds); BaseContainer *subdivData = hN->GetDataInstance(); subdivData->SetLong(SDSOBJECT_SUBEDITOR_CM, 2); subdivData->SetLong(SDSOBJECT_SUBRAY_CM, 3); //// DISPLACER //// BaseObject *dP1 = BaseObject::Alloc(1018685); //Create Displacer Object BaseContainer *dispData = dP1->GetDataInstance(); dispData->SetReal(MGDISPLACER_DISPLACEMENT_HEIGHT, 30); //Displacement Height dispData->SetLong(MGDISPLACER_DISPLACEMENTMODE, 0); //Intensity Mode dispData->SetLong(MGDISPLACER_POLYNORMALMODE, 1); //Spherical Mode //// STACK OBJECTS //// dP1->InsertUnder(groupNull); cube->InsertUnder(hN); hN->InsertUnder(groupNull); return groupNull; } {
So what it`s doing is creating a Null, creating a Cube, creating a Hypernurbs, creating a Displacer and grouping it all together under the Null.
This works great except for the Displacement settings ( MGDISPLACER_DISPLACEMENT_HEIGHT etc ). Those are throwing undeclared identifier errors..
Any ideas what the problem is here?
Im thinking maybe im missing an #import or something?
m thinking maybe i
Pretty much working in the dark as the only reference to these id`s in in the actual raw html of the help files..
On 26/06/2014 at 04:26, xxxxxxxx wrote:
Adding this include worked:
#include "C:\Program Files\MAXON\CINEMA 4D R14\modules\mograph\res\description\omograph_displacer.h"
Prob better converting it to a relative address also..
On 26/06/2014 at 09:45, xxxxxxxx wrote:
You can use "../../modules/mograph/res/description/omograph_displacer.h" or add the path to the projects additional include directories (but add them as relative paths, too).
-Niklas
