Spline Description
On 17/06/2014 at 13:43, xxxxxxxx wrote:
Cinema 4D Version: 14
Platform: Mac ;
Hi,I have a spline parameter declared in GetDDescription() like this:
cid = DescLevel(idSpline, CUSTOMDATATYPE_SPLINE, 0); if (!singleid || cid.IsPartOf(*singleid,NULL)) { BaseContainer bc; bc = GetCustomDataTypeDefault(CUSTOMDATATYPE_SPLINE); bc.SetString(DESC_NAME,"Time"); if(!description->SetParameter(cid, bc, DescBaseGroup)) return TRUE; }
This seems to work perfectly, except when I right click on it in the Attribute Manager and click Show in separate window, it opens an empty dialog.
Is there a setting or something I'm missing?
As always, thanks!
Dan
On 19/06/2014 at 02:55, xxxxxxxx wrote:
I did asked the same question and Niklas would forward it to the developers.
No answer yet.Originally posted by xxxxxxxx
Unfortunately, I don't have a solution for you right now. I've forwarded this to the developers.
Best,
-Niklas
On 19/06/2014 at 14:33, xxxxxxxx wrote:
Ah, that didn't show up to me when I was doing my search because I was looking for CUSTOMDATATYPE_SPLINE instead of CUSTOMGUI_SPLINE, thanks for the info.
I am trying to get a spline in the node description, instead of a dialog, I'm not sure if that is a different problem or the same one.
Thanks!
Dan
On 25/06/2014 at 15:03, xxxxxxxx wrote:
I figured out the problem I was having with the node description, I had messed up my group parameter descriptions, fixing those made it work.
Dan
