On 14/06/2014 at 23:40, xxxxxxxx wrote:
I put this script together to write the points and polys to a file to use again some place else. It worked a few times but not anymore. I tried it in a new python node but still not working.
import c4d #Welcome to the world of Python obj = doc.SearchObject("Head")
def All_Points() : obj_points = obj.GetAllPoints() obj_poly = obj.GetAllPolygons() PointFile = "D:\Users\Carel\Desktop\Point.txt" Point_File = open('Point.txt','w') for i, line in enumerate(obj_points) : point_Ind = i point_Ln = line Point_File.write("mypoly.SetPoint(" + str(point_Ind) + ",c4d." + str(point_Ln) + ")" + '\n') Point_File.close() PolyFile = "D:\Users\Carel\Desktop\Poly.txt" Poly_File = open('Poly.txt','w') for i, line in enumerate(obj_poly) : poly_Ind = i poly_Ln = str(line) Str_Line = poly_Ln.translate(None,"abcd:") Poly_File.write("mypoly.SetPolygon(" + str(poly_Ind) + ",c4d.CPolygon" + str(Str_Line) + ")" + '\n') Poly_File.close() def Selected_Points() : Pts_List = [] Max_Pts = obj.GetPointCount() Sel_Pts = obj.GetPointS() PointFile = "D:\Users\Carel\Desktop\Sel_Points.txt" Point_File = open('Sel_Points.txt','w') for index, selected in enumerate(Sel_Pts.GetAll(Max_Pts)) : if not selected: continue else: Pts_List.append(index) print Pts_List Point_File.write(str(Pts_List) + '\n') def main() : if Input1 == True: return All_Points() if Input2 == True: return Selected_Points()
I don't get any errors, nothing. Please anyone
On 15/06/2014 at 06:40, xxxxxxxx wrote:
Ok I got it working again. The red color is what needs changing:
def All_Points() : obj_points = obj.GetAllPoints() obj_poly = obj.GetAllPolygons() PointFile = "D:\Users\Carel\Desktop\Point.txt" Point_File = open(PointFile,'w') for i, line in enumerate(obj_points) : point_Ind = i point_Ln = line Point_File.write("mypoly.SetPoint(" + str(point_Ind) +
",c4d." + str(point_Ln) + ")" + '\n') Point_File.close() PolyFile = "D:\Users\Carel\Desktop\Poly.txt" Poly_File = open(PolyFile,'w') for i, line in enumerate(obj_poly) : poly_Ind = i poly_Ln = str(line) Str_Line = poly_Ln.translate(None,"abcd:") Poly_File.write("mypoly.SetPolygon(" + str(poly_Ind) +
",c4d.CPolygon" + str(Str_Line) + ")" + '\n') Poly_File.close() def Selected_Points() : Pts_List = [] Max_Pts = obj.GetPointCount() Sel_Pts = obj.GetPointS() PointFile = "D:\Users\Carel\Desktop\Sel_Points.txt" Point_File = open(PointFile,'w') for index, selected in enumerate(Sel_Pts.GetAll
