On 07/06/2014 at 08:23, xxxxxxxx wrote:
User Information: Cinema 4D Version: 14 Platform: Mac OSX ; Language(s) : C++ ;
--------- Why is it that Xcode keeps telling me that:
No member named 'IntToString' in 'String'
in this line:
GePrint("RGB Loaded:"+String::IntToString(count));
On 07/06/2014 at 08:40, xxxxxxxx wrote:
'cause you're using R14. Use LongToString() (global function)
-Niklas
On 08/06/2014 at 05:28, xxxxxxxx wrote:
Howdy,
Originally posted by xxxxxxxx Why is it that Xcode keeps telling me that: No member named 'IntToString' in 'String' in this line: GePrint("RGB Loaded:"+String::IntToString(count));
This would be an example where the compiler directives I mentioned in the other thread would come in handy to create wrapper functions:
String MyLongToString(LONG l) { #if API_VERSION < 15000 return LongToString(l); #else return String::IntToString(l); #endif }
Then you'd simply call:
GePrint("RGB Loaded:"+MyLongToString(count))
...and compile for all versions.
Adios, Cactus Dan
On 08/06/2014 at 06:02, xxxxxxxx wrote:
Yes, you are absolutely right, Dan I still have to start creating all those utility wrappers.
