On 03/06/2014 at 16:01, xxxxxxxx wrote:
User Information: Cinema 4D Version: 14 Platform: Mac OSX ; Language(s) : C++ ;
--------- I my shader parameters I have a link field that can be empty or contain a tag (a custom tag that I created). How, in C++ can I get the content of the link field? I'm using this code:
BaseContainer * data = sh->GetDataInstance(); BaseTag * the_tag = (BaseTag* ) data->GetBaseLink(TAG_OBJECT);
But this seems to crash Cinema4D. Damn! So many castings!!! What am I doing wrong?
On 03/06/2014 at 20:16, xxxxxxxx wrote:
Try it like this.
//This is an example of getting the tag the user has dropped into the link gizmo with the ID of MYLINK //In this case the tag is a custom tag...So we get it by it's plugin ID# INITRENDERRESULT MyShader::InitRender(BaseShader *sh, const InitRenderStruct &irs) { BaseContainer *data = sh->GetDataInstance(); BaseTag *myTag = (BaseTag* )data->GetLink(MYLINK, GetActiveDocument(), TAG_PLUGIN_ID); if(myTag) GePrint(myTag->GetName()); return INITRENDERRESULT_OK; }
On 04/06/2014 at 02:41, xxxxxxxx wrote:
Thank you so much, Scott. Got it working (still lots to do, though). Can't help thinking that this is way more complex than:
def InitRender(self,sh,irs) : the_tag=sh[TAG_OBJECT] if the_tag is None: return c4d.INITRENDERRESULT_ASSETMISSING print the_tag.GetName()
Also, GePrint requires a string and not all types of objects can be converted to strings. In python, if I print the_tag, I get something like:
<c4d.BaseTag object called 'myshader/myshader' with ID 1234567 at 0x1128956b0>
Can't I do the same in C++?
On 04/06/2014 at 02:55, xxxxxxxx wrote:
If you would've used a static_cast instead of a C-style cast, you would've seen an error at compilation time.
Also, GePrint requires a string and not all types of objects can be converted to strings. In python, if I print the_tag, I get something like: <c4d.BaseTag object called 'myshader/myshader' with ID 1234567 at 0x1128956b0> Can't I do the same in C++?
You can write yourself a little print function. You can use IsInstanceOf() to check if you got a tag, object or shader, etc.
-Niklas
On 04/06/2014 at 07:25, xxxxxxxx wrote:
You might want to take a quick look at the second part of my C++ video tutorial Rui. I explain a few of the fundamentals like the GePrint(). C++ requires more typing. But it's not necessarily "harder" than Python. More typing != harder.
One of the most common things that is used in the C4D SDK is descriptions. Almost every time you see this in Python: obj[FOO] = fooValue It requires this in C++: obj->SetParameter(DescID(FOO), GeData(fooValue), DESCFLAGS_SET_0);
Python wraps things up into tiny little packages that are short to type. But it's not "easier" than C++. Once you type this stuff few hundred times. You won't notice it so much. Also once you have built up enough C++ notes. You'll cut an paste a lot of code instead of typing it.
The way I often work is that I play around in Python and try out a few ideas. Then once I have the idea formed into a solid idea. I then switch over to C++ and make the actual plugin there. If you can seamlessly jump back and forth from Python & C++. You'll have C4D by the nuts.
