Render Shader to image
On 03/06/2014 at 09:18, xxxxxxxx wrote:
I am trying to figure out how to take a shader such as the fusion or layer shader and save the output as a an image file. I've noticed the c4d.BaseShader has an example in the doc but does not work with any shaders other than Xbitmap.
material = doc.GetFirstMaterial() shader = material[c4d.MATERIAL_COLOR_SHADER] irs = render.InitRenderStruct() if shader.InitRender(irs)==c4d.INITRENDERRESULT_OK: bitmap = shader.GetBitmap() shader.FreeRender() if bitmap is not None: bitmaps.ShowBitmap(bitmap)
Does anyone know of any examples that show how this can be done?
On 03/06/2014 at 22:02, xxxxxxxx wrote:
The docs are pretty clear about what GetBitmap() does:
Originally posted by xxxxxxxx
Returns the bitmap of shaders of type Xbitmap, otherwise None.
Use Sample() to get the color for a pixel and write this to a new Bitmap.
-NIklas
On 04/06/2014 at 08:40, xxxxxxxx wrote:
Thanks for the help Niklas.
So I think I have the initial idea down as to getting the pixel information using the following code:
import c4d from c4d import Vector, bitmaps from c4d.modules.render import ChannelData, InitRenderStruct def main() : w = 10 h = 10 mat = doc.GetActiveMaterial() mati = mat[c4d.MATERIAL_COLOR_SHADER] irs = InitRenderStruct() mati.InitRender(irs) cd = ChannelData() cd.p = Vector(.5, .5, .5) print mati.Sample(cd) bitmap = bitmaps.BaseBitmap() bitmap.FlushAll() bitmap.Init(w,h, depth=8,flags = 0) pos = [1,1] col = [200,200,200] bitmap.SetPixel(pos[0],pos[1],col[0],col[1],col[2]) bitmaps.ShowBitmap(bitmap) if __name__=='__main__': main()
When I show the bitmap however it is all black, am I missing something?
On 04/06/2014 at 12:36, xxxxxxxx wrote:
Ok I figured it out!
For anyone trying to do the same here is some code to get you started. (so far it's working
from __future__ import division import c4d from c4d import Vector, bitmaps from c4d.bitmaps import ShowBitmap from c4d.modules.render import ChannelData, InitRenderStruct def main() : w = 100 h = 100 mat = doc.GetActiveMaterial() shader = mat[c4d.MATERIAL_COLOR_SHADER] irs = InitRenderStruct() shader.InitRender(irs) cd = ChannelData() cd.p = Vector(.5,.5,0) bmp = bitmaps.BaseBitmap() bmp.Init(w,h,24) print shader.Sample(cd) for x in xrange(w) : for y in xrange(h) : PX = x/w PY = y/h cd.p = Vector(PX,PY,0) s = shader.Sample(cd) r = int(s.x * 255) g = int(s.y * 255) b = int(s.z * 255) bmp.SetPixel(x, y, r, g, b) shader.FreeRender() ShowBitmap(bmp) if __name__=='__main__': main()
