ProgressDialog..
On 01/06/2014 at 15:58, xxxxxxxx wrote:
Cinema 4D Version:   R14
Platform:   Windows  ;
I`ve called a ProgressDialog from within my ObjectData plugin and trying to figure out how to properly update the progress.
In the sdk docs there`s an example and what this does is override the virtual Main() function and run a for/next loop inside it to demonstrate the progress bar updating..
This works fine but when i try a similar thing ( using my own custom percentage variable which is updated elsewhere in the plugin ) it only seems to read the value of the variable as it is when the ProgressDialog is initially instantiated - ie it`s not reading the updated value as it updates elsewhere.
Here`s an example of my Main() override:
void MyProgressDialog::Main(C4DThread *bt)
	SetPercent(0.f);
	while (progPercent != 1)
		GePrint(RealToString(progPercent));      // only ever prints zero or whatever initial value i set,
		SetPercent((Real) progPercent);  // and doesnt recognise that progPercent is being updated elsewhere.
	SetPercent(1.f);
To be honest im probably overlooking something obvious and maybe theres an alternative to using While to check the variable, but any advice would be appreciated!
