On 01/06/2014 at 15:50, xxxxxxxx wrote:
I'm creating a shader and I need to know what face is being rendered (the index of the face). I already have the object that is being rendered (the shader works in junction with a tag and it is easy to get the object that is using the tag) and the object must ALWAYS be polygonal. So, inside my shader I already have the object and I'm sure it is polygonal. But I want to know how to be able to find what face is being rendered. I tried using something like this:
def Output(self, sh, cd) : op=None the_tag=sh[VMAP_OBJECT] if the_tag is not None: op=the_tag.GetObject() op_type=op.GetType() if op_type != c4d.Opolygon: return c4d.Vector(0) # return black if it isn't a polygonal object
if cd.vd: #if shader is computated in 3d space volumedata=cd.vd ray=volumedata.ray
collision=c4d.utils.GeRayCollider() collision.Init(op,False)
hit=collision.Intersect(ray.p,ray.v,volumedata.dist+1.0,False)
if hit is True: print collision.GetIntersection(0)["face_id"]
return c4d.Vector(1.0,0,.5) else: #if shader is computated in 2d space return c4d.Vector(0.0,1.0,0.0)
But it is not detecting any intersection. Am I doing it wrong?
On 01/06/2014 at 16:22, xxxxxxxx wrote:
Ok, found it. Instead of simply using the ray.p value I defined:
op_matrix=op.GetMg() start=~op_matrix*ray.p
And used the start variable in the Intersect instead of ray.p and it worked. Also, I used GetNearestIntersection instead of GetIntersection.
