On 30/05/2014 at 05:51, xxxxxxxx wrote:
Is is possible to create an Xpresso node in Python?
On 30/05/2014 at 06:19, xxxxxxxx wrote:
Hi Rui,
you can create a node with this code:
XP=c4d.BaseTag(c4d.Texpresso) # create the xpresso tag op.InsertTag(XP) # add the xpresso tag Node_M=XP.GetNodeMaster() # now create the object node Bas_Node=Node_M.CreateNode(Node_M.GetRoot(), c4d.ID_OPERATOR_OBJECT, None, 330, 200 )
you´ll find more informations here: http://www.maxonexchange.de/sdk/CINEMA4DPYTHONSDK/help/modules/c4d.modules/graphview/GvNode/index.html?highlight=node#GvNode.SetOperatorContainer
Cheers Martin
On 30/05/2014 at 07:18, xxxxxxxx wrote:
I don't mean creating an already existing node inside an Xpresso tag. I mean, is it possible to create a new node, just like I can create new tags and objects plugins?
On 30/05/2014 at 08:01, xxxxxxxx wrote:
With this you have to define your ports an stuff like this by yourself than:
Bas_Node=Node_M.CreateNode(Node_M.GetRoot(), c4d.ID_GV_OPERATOR_DUMMY, None, 330, 200 )
On 30/05/2014 at 08:07, xxxxxxxx wrote:
But how can I create a python plugin that is placed in the plugins folder that will appear as a new node in the nodes list of Xpresso?
On 30/05/2014 at 09:44, xxxxxxxx wrote:
It's not possible with Python (state R15).
On 31/05/2014 at 04:48, xxxxxxxx wrote:
Damn!!
Thank you, Niklas.
