On 19/05/2014 at 23:06, xxxxxxxx wrote:
I'm creating a plane (polygon with 4 points) and making it a child of a Subdivision Surface. I'm then adding two tags:
uvw tag: c4d.BaseTag(c4d.Tuvw) and Subdivision Surface Weight: c4d.BaseTag(c4d.Tsds)
I have two problems. C4D pops a message box that says "Tag 5671 not in sync." when you try to do something with the plane. That is the uvw tag. If I drag the tag around in the object browser, the problem goes away. How do you make the tag 'in sync' in python.
Second problem: I need to set the vertex weights of the 4 points for the Subdivision Surface. In the viewport, you select the vertices and hold down 'period' and drag left & right to set them. How do you set those weights with python?
Thanks
On 20/05/2014 at 02:27, xxxxxxxx wrote:
I can answer you for the first one.
UVW Tag is a Variable Tag, you add it with MakeVariableTag()
polycount = op.GetPolygonCount() uvw = op.MakeVariableTag(c4d.Tuvw, polycount)
More info in the doc : http://www.maxonexchange.de/sdk/CINEMA4DPYTHONSDK/help/modules/c4d/C4DAtom/GeListNode/BaseList2D/BaseTag/VariableTag/index.html
On 20/05/2014 at 12:08, xxxxxxxx wrote:
César,
Thanks that worked.
For some reason this method creates a tag that is not 'in sync' with the object properly. uvw_tag = c4d.BaseTag(c4d.Tuvw) obj.InsertTag(uvw_tag)
Now for the second problem. Does anyone know how to set the vertex weights from python?
On 05/06/2014 at 20:01, xxxxxxxx wrote:
I was told by Maxon that this can't be done currently. This feature has now been put on request to the Maxon devs.
I'm loading a plane with tags from a .c4d file to achieve the same thing for now.
