Colorize OM icons?
On 16/05/2014 at 13:09, xxxxxxxx wrote:
Cinema 4D Version:   R13+
Howdy,
Is it possible to colorize the object icons in the Object Manager, like the native joints in R13+?
I did a search for "colorize icon" but came up with nothing.
Adios,
Cactus Dan
On 18/05/2014 at 01:49, xxxxxxxx wrote:
Hi Dan,
It is possible, we did this in our original release of X-Particles. The user could choose a colour from a description element and colorize an object's icon with that. It worked fine, but we dropped it in later versions - I can't remember why now!
What we did was have a monochrome image for the object icon. Then the user colour was multiplied into that to recolour the icon. The code from Message() in the ObjectData plugin looked like this:
Bool XSystem::Message(GeListNode *node, LONG type, void *data)
     BaseDocument *doc;
     BaseContainer *nodebc;
     BaseObject *op = (BaseObject* )node;
     LONG x, y;
     GetCustomIconData *cid;
     UWORD r, g, b;
     Real pixr, pixg, pixb;
     Filename sysic;
     Vector colicn;
     nodebc = op->GetDataInstance();
     doc = node->GetDocument();
     switch(type)
     case MSG_GETCUSTOMICON:
          cid = (GetCustomIconData* )data;
          if(cid)
               colicn = nodebc->GetVector(XOVM_ICONCOLOR); // description COLOR element
               GetIcon(OXPSystemIcon, cid->dat);           // OXPSystemIcon registered in main.cpp
               sysic = GeGetPluginPath() + Filename("res") + Filename("sysicon.tif");            // monochrome icon for this object
            // sysbm is a BaseBitmap class-level variable AutoAlloc'ed in the class definition
               if(sysbm && sysbm->Init(sysic) == IMAGERESULT_OK)
                    for(y = 0; y < 32; y++)
                         for(x = 0; x < 32; x++)
                              sysbm->GetPixel(x, y, &r;, &g;, &b;);
                              pixr = Real(r) /255 * colicn.x;
                              pixg = Real(g) / 255 * colicn.y;
                              pixb = Real(b) / 255 * colicn.z;
                              r = (pixr * 255);
                              g = (pixg * 255);
                              b = (pixb * 255);
                              sysbm->SetPixel(x, y, (LONG)r, (LONG)g, (LONG)b);
                    cid->dat->bmp = sysbm;
                    cid->filled = TRUE;
          break;
//.... etc.....
The crucial things are the monochrome icon to start with and that you must be able to get its bitmap. I registered the icon in main.cpp to make that easy.
Steve
On 19/05/2014 at 06:03, xxxxxxxx wrote:
Howdy,
Thanks. 😉
Adios,
Cactus Dan
