On 05/05/2014 at 07:47, xxxxxxxx wrote:
Hi After 2 weeks of trail and error i managed to write 8 lines of (python)code that adds a Null with a Xpresso tag to the object manager after pressing the button.
it works fine, a input dialog pops up so i can give the null a name and a color picker dialog to give the icon a color. But i dont want to use the color picker i just want to give the RGB values somewhere in the code and skip the colorpicker
i have no idea how to do that.
im not a developer and its my first post so sorry if its not in the right place. this is the code.
import c4d from c4d import documents from c4d import gui
usrInput = raw_input('type text here: ') #Input dialog to name myobject
def main() : #create the xpressoNULL myobject = c4d.BaseObject(c4d.Onull) #create a null object (myobject) doc.InsertObject(myobject) #Insert the object into the documents object manager myobject.MakeTag(1001149) #Add xpresso tag to myobject myobject[c4d.ID_BASELIST_NAME] = usrInput #Give myobject a name (comes from the input dialog)
iconColor = c4d.gui.ColorDialog(0) #Color Picker to color myobject myobject[c4d.NULLOBJECT_ICONCOL] = True #Set "Icon Color" on in basic tab myobject[c4d.ID_BASEOBJECT_USECOLOR] = True #Set " Use Color" on automatic in basic tab myobject[c4d.ID_BASEOBJECT_COLOR] = iconColor #set "Display Color" in basic tab #Refresh the managers to show the new object c4d.EventAdd() main()
KC
On 05/05/2014 at 08:06, xxxxxxxx wrote:
op[c4d.ID_BASEOBJECT_COLOR]=c4d.Vector(1,0,0)
this is a pure red
The vector represents the rgb values, like c4d.Vector(R,G,B), in the range from 0 to 1
cheers martin
On 05/05/2014 at 08:18, xxxxxxxx wrote:
Thanks Martin it works
kc
