Disable move option in the viewport
  • On 16/04/2014 at 23:45, xxxxxxxx wrote:
    Cinema 4D Version:   R13
    Platform:   Windows  ;
    Hello all,
    i am trying at the moment to disable the move option in the viewport, from the code, but only
    for certain types of objects.
    In case the object tree is like this:
    ObjectType1
             ObjectType2
                       ObjectType3
    All object types should be selectable. This means that in the viewport they can also be moved.
    But i want this only for ObjectType2. ObjectType1 and ObjectType2 should be selectable, but they cannot be moved in the viewport.
    Is there any way to do this from my plugin code ?
    Thank you in advance for all your responses.
  • On 17/04/2014 at 14:10, xxxxxxxx wrote:
    Hello Pia,
    Take a look at GeListNode::ChangeNBit(). You can use the NBIT_PROTECTION constant to
    lock PSR on the object. Make sure to unset the bit when you are done, the user has no visual
    access to modify this bitflag.
    Best,
    -Niklas
  • On 13/05/2014 at 04:33, xxxxxxxx wrote:
    Hello Niklas,
    victory !
    this is exactly what i was looking for and it works wonderfully
    Thank you very much for the help.
