Slow response from FilterPluginList()
On 12/04/2014 at 11:30, xxxxxxxx wrote:
Hi
I made small concept of realtime-switch command for simple brush tool
Based at py-tag at PointOp.It simply switches mode between smear and if Shift pressed button - for smooth mode in brush tool
import c4d from c4d import plugins from c4d.gui import GetInputState def lkmtest() : bc = c4d.BaseContainer() rs = GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, bc) if rs and bc[c4d.BFM_INPUT_VALUE]: return True return False def shft_pressed() : bc = c4d.BaseContainer() rs = GetInputState(c4d.BFM_INPUT_KEYBOARD, c4d.KEY_SHIFT, bc) if rs and bc[c4d.BFM_INPUT_VALUE]: return True return False def main() : actidtool = doc.GetAction() toolPlugins = plugins.FilterPluginList(c4d.PLUGINTYPE_TOOL, True) if actidtool == 1016202: for plugin in toolPlugins: if plugin.GetName()=="Brush": while lkmtest() : if shft_pressed() : plugin[c4d.MDATA_BRUSH_MODE]=c4d.MDATA_BRUSH_MODE_SMOOTH c4d.EventAdd() break else: plugin[c4d.MDATA_BRUSH_MODE] = c4d.MDATA_BRUSH_MODE_SMEAR c4d.EventAdd() break
Small question how can to replace FilterPluginList?
findPlugin does not work, seems
On 12/04/2014 at 23:10, xxxxxxxx wrote:
FindPlugin works
another version, switch between smooth and surface modesimport c4d from c4d import plugins from c4d.gui import GetInputState def lkmtest() : bc = c4d.BaseContainer() rs = GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, bc) if rs and bc[c4d.BFM_INPUT_VALUE]: return True return False def shft_pressed() : bc = c4d.BaseContainer() rs = GetInputState(c4d.BFM_INPUT_KEYBOARD, c4d.KEY_SHIFT, bc) if rs and bc[c4d.BFM_INPUT_VALUE]: return True return False def main() : actidtool = doc.GetAction() if actidtool == 1016202: tool = plugins.FindPlugin(actidtool, c4d.PLUGINTYPE_TOOL) while lkmtest() : if shft_pressed() : tool[c4d.MDATA_BRUSH_MODE]=c4d.MDATA_BRUSH_MODE_SMOOTH tool.Message(c4d.MSG_TOOL_RESTART) c4d.EventAdd() break else: tool[c4d.MDATA_BRUSH_MODE] = c4d.MDATA_BRUSH_MODE_SURFACE tool.Message(c4d.MSG_TOOL_RESTART) c4d.EventAdd() break
On 13/04/2014 at 07:36, xxxxxxxx wrote:
Is this code being used in a pyton tag. Or in your own tool plugin?
If you're using it in a python tag. It's not working properly for me in R13.
The problem is I'm not allowed to change a tool's attribute while the LMB is being held down.
So what happens is the mode doesn't change until after I release the LMB. And that's too late.Does it work differently in later versions?
Or are you maybe using this in a plugin instead?-ScottA
On 13/04/2014 at 08:13, xxxxxxxx wrote:
It works at R15
Planning to make complex tool for tag- or tool-plugin for pyAPI
And maybe port to CAPI or i do nothing, just for fun and improving of experience with pyAPI(i'm not programmer)
On 13/04/2014 at 09:38, xxxxxxxx wrote:
OK. Thanks.
I guess they added multi-threading for the python tag in R15. Because it doesn't work in R13.FYI. Just a heads up.
If you use c4d.EventAdd() in a python tag's code. Then you're already running in an infinite loop.
So you don't need to use while loops to check for key presses. Using "If" statements will be enough.
Using while loops like that, when you're already running inside of a loop, can slow down your code execution.-ScottA
On 13/04/2014 at 10:26, xxxxxxxx wrote:
Scott, thank you for a heads up!
found, it did not work
that i put while, while we work with mouse and we can switch to smoothI removed events in second version and really speeds up
(sorry for my english)
