Multiple SubDialogs
On 08/04/2014 at 14:14, xxxxxxxx wrote:
Figured it out!After typing it out above I realized RestoreLayout() was misspelled. Thank you guys for all the help!*Edit there is a new problem the setup:
def Restore(self, pluginid, secref) : if secref['subid'] == 1: print "Color" return self.RB_ColorDLG.Restore(pluginid,secref) if secref['subid'] == 2: print "Temp" return self.RB_TempDLG.Restore(pluginid,secref) else: print "Main" return super(BuddyDialog, self).Restore(pluginid,secref)
This causes cinema to crash. I will restore the layout but if you launch the sub dialog again everything locks up. This happens with the Example as well.
On 08/04/2014 at 16:01, xxxxxxxx wrote:
Hi Shawn, I can reproduce the problems you have described. The Example I posted worked though,
but funnily broke after a few more times testing it. I'll have to talk to a developer on this, I am pretty
sure this is a bug. Especially this message isTraceback (most recent call last) :
File "'restore-sub-dialog.pyp'", line 57, in CreateLayout
SystemError: error return without exception setBest,
-Niklas
On 08/04/2014 at 16:19, xxxxxxxx wrote:
Thank you Niklas.
-Shawn
On 08/04/2014 at 19:28, xxxxxxxx wrote:
It seems to work just fine for me. No errors or problems at all.
Maybe you're trying to do something different than I'm doing?Here is a complete example that works fine for me in R13.
Save it as a .pyp file and put it in your plugins folder.
The main dialog has buttons to open two other dialogs. And a button that will change the checkbox gizmo in dilaog1.
All three dialogs can be docked into the UI and saved in a custom layout.#This is an example of a GeDialog plugin that opens three dialogs #It also allows all three dialogs to be docked and saved in a custom layout import c4d, os from c4d import gui, plugins, bitmaps PLUGIN_ID = 1000004 #Testing ID SUBDLG_ID1 = 1000005 #Testing ID SUBDLG_ID2 = 1000006 #Testing ID MAINDLG_BUTTON1_ID = 1000 MAINDLG_BUTTON2_ID = 1001 MAINDLG_BUTTON3_ID = 1002 SUBDLG_TEXT_ID = 1003 SUBDLG_CHKBOX_ID = 1004 SUBDLG_RESET_ID = 1005 ############################ #The first sub dialog class SubDialog1(c4d.gui.GeDialog) : def CreateLayout(self) : self.SetTitle('Sub-Dialog1') self.GroupBeginInMenuLine() self.AddCheckbox(SUBDLG_RESET_ID, c4d.BFH_RIGHT, 100, 20, name="Reset") self.GroupEnd() self.GroupBegin(0, c4d.BFH_SCALEFIT, 2, 0, "MyGroup") self.GroupBorderSpace(5, 5, 5, 5) self.GroupBorder(c4d.BORDER_BLACK) self.AddStaticText(SUBDLG_TEXT_ID, c4d.BFH_LEFT, 200, 20, "This is the sub-dialog1") self.AddCheckbox(SUBDLG_CHKBOX_ID, c4d.BFH_LEFT, 20, 20, "myChkbox") self.GroupEnd() return True def Command(self, id, msg) : if id == SUBDLG_RESET_ID: self.SetBool(SUBDLG_CHKBOX_ID, False) self.SetBool(SUBDLG_RESET_ID, False) return True ############################ #The second sub dialog class SubDialog2(c4d.gui.GeDialog) : def CreateLayout(self) : self.SetTitle('Sub-Dialog2') self.GroupBeginInMenuLine() self.AddCheckbox(SUBDLG_RESET_ID, c4d.BFH_RIGHT, 100, 20, name="Reset") self.GroupEnd() self.GroupBegin(0, c4d.BFH_SCALEFIT, 2, 0, "MyGroup") self.GroupBorderSpace(5, 5, 5, 5) self.GroupBorder(c4d.BORDER_BLACK) self.AddStaticText(SUBDLG_TEXT_ID, c4d.BFH_LEFT, 200, 20, "This is the sub-dialog2") self.AddCheckbox(SUBDLG_CHKBOX_ID, c4d.BFH_LEFT, 20, 20, "myChkbox") self.GroupEnd() return True def Command(self, id, msg) : if id == SUBDLG_RESET_ID: self.SetBool(SUBDLG_CHKBOX_ID, False) self.SetBool(SUBDLG_RESET_ID, False) return True ############################ #The main dialog class MainDialog(c4d.gui.GeDialog) : sub_dialog1 = SubDialog1() sub_dialog2 = SubDialog2() def CreateLayout(self) : self.SetTitle('Main Dialog') self.AddButton(MAINDLG_BUTTON1_ID, 0, name="Open Sub-Dialog1") self.AddButton(MAINDLG_BUTTON2_ID, 0, name="Open Sub-Dialog2") self.AddButton(MAINDLG_BUTTON3_ID, 0, name="Change Sub-Dialog1") return True def Command(self, id, msg) : if id == MAINDLG_BUTTON1_ID: self.sub_dialog1.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=SUBDLG_ID1) if id == MAINDLG_BUTTON2_ID: self.sub_dialog2.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=SUBDLG_ID2) if id == MAINDLG_BUTTON3_ID: self.sub_dialog1.SetBool(SUBDLG_CHKBOX_ID, True) return True #Restore the subdialog and the main dialog in the layout def Restore(self, pluginid, secref) : if secref['subid'] == SUBDLG_ID1: return self.sub_dialog1.Restore(pluginid, secref) if secref['subid'] == SUBDLG_ID2: return self.sub_dialog2.Restore(pluginid, secref) else: return super(MainDialog, self).Restore(pluginid, secref) ############################ #The Command Data section class MainDialog_CD(c4d.plugins.CommandData) : @property def dialog(self) : if not hasattr(self, '_dialog') : self._dialog = MainDialog() return self._dialog def Execute(self, doc) : return self.dialog.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID) def RestoreLayout(self, secref) : return self.dialog.Restore(PLUGIN_ID, secref) if __name__ == "__main__": bmp = bitmaps.BaseBitmap() dir, file = os.path.split(__file__) fn = os.path.join(dir, "res", "icon.png") bmp.InitWith(fn) plugins.RegisterCommandPlugin(PLUGIN_ID, "Sub-Dialog Docking",0, bmp, "re-open", MainDialog_CD())
